Head gasket - Mustang Evolution
Old 06-30-2015, 06:57 PM   #1
Mustang8606's Avatar
Head gasket
Well I was looking in the engine bay and I found a small coolant leak from the head gasket. No puddles or anything, just seeping. I need some insight. Is this an immediate fix issue or do I have time on my side? I appreciate any input guys. Click image for larger version
Name:	ImageUploadedByMustang Evolution1435712182.434268.jpg
Mustang8606 is offline   Reply With Quote
Old 06-30-2015, 07:20 PM   #2
WJL
Your out of time, fix it
WJL is offline   Reply With Quote
Old 06-30-2015, 07:32 PM   #3
Any recommendations on type of gaskets?
Old 06-30-2015, 07:50 PM   #4
WJL
I have always had luck with Fel-Pro, but Ford Racing would do.
Not sure what your experience level is, just to give you some insight Ford uses Torque to yield head bolts which means they are one and done.
You can buy Head Gasket kits that include all the gaskets and bolts you need. It's not that tuff of a job and can be done with the motor in the car, good luck and post some pictures, is that an 03 or 04 cant tell from the picture?
Old 06-30-2015, 08:03 PM   #5
Thanks for the info, I'm a mech for the army but first time working on the mod motor. It's an 04, I'm getting ready for a deployment in a few months. I was curious if it could wait till after I get back. It's gonna be sitting in my garage the entire time. Once again thanks for the advice.
Old 06-30-2015, 08:22 PM   #6
jeno's Avatar
If you not driving it it will be fine
Sent from my Nexus 6 using Tapatalk
jeno is offline   Reply With Quote
Old 06-30-2015, 10:15 PM   #7
infamous281's Avatar
Idk , I would like to see more pictures of the leak.
I would do a leak down test before anything.
Ford gaskets all the way , none of the fel-pro or ford racing crap.
Sent from my SM-N910T using Mustang Evolution mobile app
Old 07-01-2015, 10:33 AM   #8
Ok, I'll post some pics when I get off work.
Old 07-01-2015, 10:37 AM   #9
jeno's Avatar
He said he wanted to store it while he deployed and work on it when he got back there will be no one driving therefore it won't harm it no run no headgasket leak
Old 07-01-2015, 02:22 PM   #10
WJL
Ok here we go, first, if you didn't know Ford Racing is FORD and Fel-Pro has been making gasket almost as long as Ford has been building cars!
A leak down test typically refers to testing a cylinder for its ability to hold a given pressure over a period of time and is measured in percentage of loss.
If you are referring to a coolant system pressure test, that would be ok but judging by the amount of coolant in the picture i'm not sure it will revel the leak.
I would do a cooling system check both warm and cold but again i would expect it to start spray coolant just because you pressurized the system.
8606, If you are just going to drive it around town, keep an eye on the coolant level just wouldn't be taking any long road trips.
Opinions are like A$$holes everyone has one, however some are better than others, just saying
Old 07-01-2015, 05:55 PM   #11
Again I really appreciate the advice. Ok so I took more pictures. I noticed that my intake at the crossover on the pass side had coolant around it. So I looked in between and sure enough the leak is forming drops right on the head gasket. I'm still going to do a leak down test and coolant pressure test. But I'm sure it's the intake.
The mustang has 88,000 miles and from what I've seen on the forum. That's when I would expect it to go. Click image for larger version
Name:	ImageUploadedByMustang Evolution1435794905.528034.jpg
ID:	186302Click image for larger version
Name:	ImageUploadedByMustang Evolution1435794921.178866.jpg
Old 07-01-2015, 06:04 PM   #12
WJL
Good investigation, the intakes are notorious for this although it was the plastic crossover that failed, looks like you have the aluminum one which is the fix for this problem.
Whatever you do don't buy the Dorman, you can get a Ford Racing intake for around $215.00 pretty much anywhere.
Old 07-01-2015, 06:25 PM   #13
Roguestang's Avatar
Whew!!! Replacing a warped or cracked intake is alot easier than doing a head gasket. As WJL said, make sure to get a PI ford racing intake, no Dorman junk. Also to nip it in the butt, there is no need to go with any other aftermarket intakes either. The oem one flows great, and holds up fine on mild boost applications. You'll want new gaskets as well (fel-pro is great). Even the updated ones with an aluminum crossover were seen to warp as well, so it's not really unusual.
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 07-01-2015, 06:58 PM   #14
Well I got the ford racing intake on order, $284 with gaskets and 3 day shipping. Thanks everyone for the help.
Old 07-06-2015, 10:36 PM   #15
alecas447's Avatar
I have the same puddle but no other symptoms yet
alecas447 is offline   Reply With Quote
Old 07-07-2015, 08:39 AM   #16
Nope, its a fix for the cracking crossover that the 99/00 cars had but it is NOT a fix for the plastic warping and cracking under the crossover. They all fail eventually, just a matter of when.
This is a 38k mile plastic intake I pulled off a 05 Vic motor. Mileage is not the factor with them, it is heat cycles and time.
Agreed about the Dorman or the AM one... ONLY buy the FRPP intake. Never buy a PI intake used or you'll likely wind up with the above picture in short order.
That's kinda steep... if you got it from LRS then you overpaid. AM still has them for $215 and gaskets are like $20. Shipping is free plus there is a 6% forum discount for AM. No idea why LRS is charging more unless Ford is now charging more and AM has not caught up yet... I should probably order mine from AM like... now lol.
Likely have the same issue in the picture I posted. Warps under the crossover and leaks. New intake cures it.
Old 07-07-2015, 01:30 PM   #17
WJL
The last time i checked AM was like $38.00 just for one head to manifold gasket $78.00 for two
Old 07-07-2015, 01:37 PM   #18
At that price it better come with a packet of analease and a scented candle...
More Information for FEL-PRO MS921213
$22 plus shipping.
Old 07-07-2015, 05:15 PM   #19
alecas447's Avatar
Where can I find the $20 gaskets for the manifold?
Old 07-07-2015, 05:24 PM   #20
natestang07's Avatar
Rockauto..com is always the answer
Old 07-07-2015, 06:44 PM   #21
alecas447's Avatar
Advanced auto parts had it for like $80 lol
Old 07-07-2015, 06:46 PM   #22
Lol, when a sentence is blue, its a link... And that's for the Fel Pros, they have cheaper ones although I would only recommend getting OEM or Fel Pro. I've never had an issue with any Fel Pro gasket ever.
Yeah **** autozone. They're good for fluids and a few other things but for actual parts... hell no. For Rockauto, use the 5% discount code in the forums here. Just google "rockauto discount mustangevolution" and it'll be the first result.
Old 07-07-2015, 07:01 PM   #23
WJL
I need a set myself, one of the local part stores "Advanced" has a Fel-pro kit Part No. MS 95728 for $23.00, not sure if its the same as rockauto.
i'm going to go look at them, from the pictures on the net they don't appear to be the same quality of the FORD gaskets.
I will also check with Ford one of the local dealers has a great parts guy who will sometimes cut you a break.
You definitely don't want to cheap out on that gasket.
There are times to take chance, i don't think this is one of them.
I will let you know what i find.
Old 07-07-2015, 07:12 PM   #24
The Fel Pro gaskets I linked to are top quality. I've bought them myself, that exact set from that exact vendor for my blue 98 that had a PI motor in it. Pictures on the interwebz are just pictures on the interwebz.
Old 07-07-2015, 07:28 PM   #25
WJL
Good to hear that, this engine swap project is starting to add up so a little price break is good.
I as well have never had any issues or concerns using Fel-Pro Gaskets.
Upper intake plenum gasket and EGR gasket McNassty General Mustang Discussion 1 06-08-2012 10:51 AM
Is a valve gasket the same as a valve cover gasket? birtingr General Mustang Discussion 6 03-15-2010 02:24 AM
leaking head gasket tedness Pre-2005 V6 Mustang 5 03-07-2005 10:06 PM
leaking head gasket...what? tedness The Bar 1 03-07-2005 09:43 PM
Cracked Head or Head Gasket problem DMustanger Pre-2005 V6 Mustang 21 12-17-2003 06:52 AM
10:19 AM
