Pumping gas problem - Mustang Evolution
Old 07-04-2015, 09:35 AM   #1
dayves's Avatar
Pumping gas problem
Ever since I bought the car it won't let me put gas in steadily the whole time. It goes for maybe a dollar worth then stops then I have to wait. I read it's the fumes not being able to escape so the gas can't flow property, is that correct?? If so, how the hell can I fix it. It's annoying wasting 10 minutes to fill up because it stops after every dollar or before. So what can I do or replace to get it fixed?? Thanks in advance
dayves is offline   Reply With Quote
Old 07-04-2015, 09:46 AM   #2
It's a bad flapper in the fill neck most likely. Will need to replace that and you should be good.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 07-04-2015, 07:27 PM   #3
XSlashDashX's Avatar
Is it the whole filler neck? Mine's doing the same.
Hitting the limiter when pumping Fuel seville 2011-2014 Mustang GT 15 03-01-2014 08:28 AM
Gas pumping tips: DarkShadow The Bar 4 09-11-2007 10:34 PM
11:35 PM
