Manifold Intake - Mustang Evolution
Old 07-04-2015, 10:56 PM   #1
joe_117's Avatar
Manifold Intake
Can anyone tell me if my manifold intake is stock or...
Yes i know my engine is dirty.
Name:	ImageUploadedByMustang Evolution1436072192.791843.jpg
joe_117 is offline   Reply With Quote
Old 07-04-2015, 11:09 PM   #2
joe_117's Avatar
Here are some better pics
Name:	ImageUploadedByMustang Evolution1436072923.411763.jpg
Name:	ImageUploadedByMustang Evolution1436072948.946564.jpg
Old 07-04-2015, 11:11 PM   #3
Steve96's Avatar
It looks stock to me from what i can tell
1996 GT
Old 07-04-2015, 11:28 PM   #4
joe_117's Avatar
Im just concerned because the metal part at the end is not on 99-01 mustangs. Said that they are plastic and leak easily.
And since it has the metal i was just concerned
Old 07-05-2015, 12:07 AM   #5
infamous281's Avatar
The aluminum cross over is a updated intake manifold that they changed over I believe in late 2001 .. to fix alot of the issues with th cracking.
It's stock .. Unless previous owner changed it out for a new one.
Sent from my SM-N910T using Mustang Evolution mobile app
Old 07-05-2015, 12:13 AM   #6
joe_117's Avatar
Ohh okay, if they changed it in the late 01s then ya it is stock.
Old 07-05-2015, 06:46 AM   #7
WJL
I agree with Steve it looks stock, if you google P.I. Intake there are hundreds of pics to compare.
You car must be a 99 or newer, only saying that because the crossover only has one temperature sender and no plug wires.
Older models have two, one for the gauge and one for the ECU.
96 thru 98 had NPI and 99 thru 04 had PI the aluminum crossover is available for all of them.
If you are looking to upgrade you cant beat the Ford Racing Intake, if you want to spend a lot of money you could buy the "EDDY" but from everything a have read o gain to be had on a n/a 2V
WJL is offline   Reply With Quote
Old 07-05-2015, 10:05 AM   #8
The picture in the original post is stone stock. Stock intake, stock plenum, stock air inlet and everything.
Nope, the FRPP intake IS the PI intake IE its the same as the stock intake. You only buy one if you are a NPI car upgrading or a 99/00 or if you need to replace your leaky PI intake manifold... like me... again. They all leak eventually under the tstat housing, even the metal crossover ones. The plastic warps.
The Eddy intake will pick up some power up top but lose a little down low which is bad for a bolt on 2V. Can't rev high enough to really make use of it and needs all the help it can get on the bottom so the PI intake is optimal.
99/00 did not have these metal crossovers, it was plastic and they ALL break early on.
Yes the 96-98 crossovers have 2 bungs for the sensors. The 01-04 and the FRPP intakes have the one bung and a boss for the second bung which is the perfect spot to drill/tap for an aftermarket water temperature gauge. Or if you buy a FRPP intake for 96-98 NPI car you need to drill/tap it for the second sensor.
Word of advice to anyone reading this. If you have a bad intake manifold, NEVER buy a used one. As I said, they all warp under the tstat housing and it doesn't matter if it is a low mileage intake, it is a matter of time and heat cycles. The pullout JY motor I bought had this problem at 38k miles as I suspected it would.
This
That happens to all of them. If you have a high mileage car and start smelling coolant, this is likely where it is.
Old 07-05-2015, 10:22 AM   #9
phatspeed7x's Avatar
If your looking to add a little horsepower you can add a nice cold air intake and bigger throttle body and plenum assembly. Like I did on mine...
~2004 GT with Bolt ons~
phatspeed7x is offline   Reply With Quote
Old 07-05-2015, 11:29 AM   #10
Maybe a little from the tb/plenum but the hot air intake isn't an upgrade from stock.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 07-05-2015, 11:57 AM   #11
joe_117's Avatar
Im saving either for the tb/pl or JLT. I have my tuner now so wont be a problem to get the most performance out of jt
Old 07-05-2015, 02:55 PM   #12
WJL
This
Also, Don't buy the Dorman lol
Old 07-05-2015, 05:05 PM   #13
Plenum / throttle body / intake will give you very minimal gains for the money spent.
Old 07-05-2015, 06:35 PM   #14
Then there is alot of wasted money on this forum...
Old 07-05-2015, 07:09 PM   #15
This is a correct statement.
Also in the aftermarket world in general. There are a LOT of things that are both snake oil and things that just give little in the way of return for the money spent.
Old 07-05-2015, 11:54 PM   #16
Cold air intakes - No power
Plenum + 75mm throttle body will give 6rwhp and around 8rwtq
Old 07-06-2015, 03:08 PM   #17
retiredvet's Avatar
The bbk 78mm tb/lower integrated unit u lose 2hp until 4200 then pick up 6hp but gain 8-12tq across the board stock. With 93r tune, ported heads, stage 1 cams and aftermarket lower it was good for 16hp and 19tq
Sent from my LG-D415 using Mustang Evolution mobile app
03 GT 13.4 @ 117MPH best 2v 4.6 w/ auto
Check out my Garage info for what I am installing at this moment~
retiredvet is offline   Reply With Quote
Boss intake manifold and the stock intake Yellow50 2011-2014 Mustang GT 43 04-26-2012 06:30 AM
Intake Manifold vs Intake Man-child jbanks 1996-2004 Mustang GT 17 08-02-2011 04:55 AM
Ported Intake Manifold..STRESS 99'sleeper Pre-2005 V6 Mustang 5 03-10-2005 08:10 AM
95 Intake manifold. Calston31 Pre-2005 V6 Mustang 6 12-05-2004 05:42 AM
Intake manifold and cylinder head jwscorpio Pre-2005 V6 Mustang 4 02-27-2004 06:49 AM
10:14 PM
