Tuning shift - Mustang Evolution
Old 07-05-2015, 08:03 AM   #1
Tuning shift
I have a automatic transmission and was wondering if that 2nd gear hard shift is bad for the tranny.
04sonic is offline   Reply With Quote
Old 07-05-2015, 08:10 AM   #2
Slater2111's Avatar
Is it tuned to do so? Or is it doing it on its own? The 4R70W is pretty robust it should be able to handle a tune on it. But if it's doing it on its own it may be a sticking accumulator and servo.
Sent from the mothership.
Slater2111 is offline   Reply With Quote
Old 07-05-2015, 08:16 AM   #3
I have the street tune from mpt tunes
Old 07-05-2015, 08:25 AM   #4
Slater2111's Avatar
You're fine. I have race on mine with 205k on it.
Old 07-05-2015, 09:45 AM   #5
Okay sweet! Thanks I just didn't want to have to invest in a new tranny haha
Old 07-05-2015, 09:51 AM   #6
Just make sure you have good fresh fluid at the right fill quantity and beat the crap out of it. I'm guessing from your username you have a 2004. This means you don't have a 4R70w, you have a 4R75w which is much much stronger. Even a regular 70w would be totally fine but a 75w doesn't even need to be upgraded if you do a built motor with a power adder. People routinely run them up into the 600rwhp+ range with no issues.
So yeah you are good to go for a long time. The 2004 Mustang GT/Mach1 automatics had the strongest automatic transmissions out of any of them until the 6R released in 2011.
Old 07-05-2015, 10:55 AM   #7
Yep I have the 2004 tranny and the car only had 28k on it so I should be good then
Old 07-05-2015, 11:37 AM   #8
Lol yeah. Do a full fluid change out on it if you have not already and it'll last forever and take everything you throw at it.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 07-05-2015, 11:39 AM   #9
Sweet thanks for all the help guys just wanted to play it safe
Old 07-05-2015, 12:11 PM   #10
One thing you will eventually want to upgrade is the converter tho. Not because it'll blow at your power level but a good aftermarket stall converter will make the car into a totally different animal.
shift indicator stuck on park, but can shift Da_xtreme 2005-2010 V6 Mustang 1 02-19-2015 06:55 AM
Mustang sport shift (shift at 3000 rpm's ?) Charlesph55 2011-2014 V6 Mustang 5 07-24-2014 09:58 AM
Annoying shift issue in Sport Shift mode... alludc 2011-2014 V6 Mustang 9 02-08-2013 02:20 AM
Econo Shift/Skip Shift Rant michael81 2011-2014 Mustang GT 17 01-30-2012 06:52 PM
FORDCHIP tuning in CALI! READ!! Autobadges.com Regional Mustang Discussion 2 08-26-2004 10:52 AM
09:49 AM
