Lowering my mustang - Mustang Evolution
Old 07-09-2015, 01:59 PM   #1
mustang_brody's Avatar
Lowering my mustang
I'm buying some lowering springs next friday it's a 1.5 inch drop can I just put the new springs on and just b cool with that or will I have to buy more stuff to make it work
mustang_brody is offline   Reply With Quote
Old 07-09-2015, 03:05 PM   #2
dwbrand's Avatar
I think you need some kind of adjustment on caster/camber. Which is why I haven't installed the springs I bought months ago...
Also, does it make a difference if you lower and retain stock struts?
2003 Ford Mustang GT
1995 Ford F150 XLT 4x4
1968 Mercury Cougar
dwbrand is offline   Reply With Quote
Old 07-09-2015, 03:11 PM   #3
Lorraine's driver
ab_mach1's Avatar
No - other than the tools, jack stands, and floor jack anyway. It would be nice if you could replace the shocks and struts, but you don't have to. Just be prepared for your ride to be kinda harsh and bouncy until you do. I tried to just do springs on my Mach 1, but ended up buying shocks and struts a few months later. Lowering springs are a nice mod.
Instagram: @ab_mach1
Old 07-09-2015, 03:14 PM   #4
Lorraine's driver
ab_mach1's Avatar
With a 1.5" drop, he might be able to get away with using camber bolts to help adjust alignment. They sell them at your local auto parts stores and American Muscle as well of course.
Old 07-09-2015, 03:21 PM   #5
dwbrand's Avatar
Good to know 👍🏻 thanks!
1968 Mercury Cougar
Old 07-09-2015, 06:32 PM   #6
Don't cheap out or half *** a lowered car. Get yourself some MM CC plates and you'll be doing it correctly and futureproofing for any later suspension mods.
Old 07-09-2015, 06:33 PM   #7
Rapinator126's Avatar
You got to do it like nathanmoutlaw on IG.
Old 07-09-2015, 06:39 PM   #8
Lorraine's driver
ab_mach1's Avatar
Don't need them if you don't slam it. Mine is on Sportlines, around 1.7" lower, and it was right on the edge of Fords alignment spec. IMO, I'd wait and do CC plates when you end up doing shock and struts, like I did. Good way to go if you don't have the money to buy it all at once.
IG: @azurebluemach
Old 07-09-2015, 06:40 PM   #9
Lorraine's driver
ab_mach1's Avatar
Lmao I just looked him up
IG: @azurebluemach
Old 07-09-2015, 08:12 PM   #10
Lol thanx yall are always a big help wen it comes to my mustang
Old 07-10-2015, 07:17 PM   #11
alecas447's Avatar
Cut the stock springs
alecas447 is offline   Reply With Quote
Old 07-10-2015, 07:45 PM   #12
Will it ride better
Old 07-10-2015, 09:27 PM   #13
No it'll ride like ****. Don't cut stock springs... SR springs are cheap enough and they are decent.
As I say a lot on here... people always have the money to do it right the second time so you might as well not cheap out. Do it right the first time. You need CC plates to properly lower a car the right way and you should not cut or heat up or ricer style your springs.
Old 07-10-2015, 10:40 PM   #14
Ight
Old 07-10-2015, 11:57 PM   #15
Steve96's Avatar
Get SR springs, Tokico or Koni STR.T shocks/struts, MM CC plates (probably not needed for 1.5" your call on that as i went with the HR Supersports and my CC plates werent really needed but i had them anyway the tech said it would have been very close to factory spec without them but they did help some and if i go lower ever), new Moog ball joints while youre in there, and you will have a decent more budget lowering job done with quality parts.
1996 GT
Old 07-10-2015, 11:58 PM   #16
Steve96's Avatar
You can always buy new poly isolaters or wrap your springs and leave them out for a little lower of a drop too
1996 GT
Old 07-11-2015, 06:44 PM   #17
alecas447's Avatar
I met some dude he cut the stock springs at about 2.5 front and rear it didn't look too bad
Old 07-12-2015, 05:38 PM   #18
Yeah it'll look ok...try riding in it...
Old 07-12-2015, 05:40 PM   #19
oxford5pointoh's Avatar
You will need a new tailbone
IG @Oxford5pointoh
Old 07-12-2015, 07:40 PM   #20
Slater2111's Avatar
IG @Oxford5pointoh
And that is one reason why I got rid of my prelude. I put in $1300 coil overs to replace the suspension and it dropped way too far. It was rough and hard. I'm doing my drop right the first time. I've already got koni Orange and am adding MM CC plates and Ford B springs. Little drop progressive rate firmer than stock. Should be a great cruiser and street machine.
Sent from the mothership.
Slater2111 is offline   Reply With Quote
Old 07-12-2015, 11:12 PM   #21
Just do it right the first time.
Name:	ImageUploadedByMustang Evolution1436764356.752339.jpg
Old 07-13-2015, 06:41 AM   #22
Attachment 187014
But I saw some dude on the internet who lowered his car for $100 and claimed it rides great!
Old 07-13-2015, 11:36 PM   #23
Lowering springs + cc plates and done. Said before but check those isolators. If you don't mind a slightly stiffer ride then that's that. For the look I think that's all you need. Not to mention getting better handling out of your lowered car.
wawanesa5speed is offline   Reply With Quote
Would 95 mustang gt lowering springs lower a 2000 v6 mustang greenstang41 Pre-2005 V6 Mustang 10 04-11-2013 05:32 PM
Lowering a 05-09 Mustang? 1RNKPNY 2005-2010 Mustang GT 3 03-08-2009 07:55 PM
11:44 PM
