Customizing ideas..?? - Mustang Evolution
Old 07-11-2015, 01:36 PM   #1
dayves's Avatar
For starters, here's the car with the rims 😁. Click image for larger version
Name:	ImageUploadedByMustang Evolution1436643300.393998.jpg
What I want to do is around all the windows, windshield and rear windshield, paint the stripping around them all silver to make it a little different. What're ya'lls thoughts??
dayves is offline   Reply With Quote
Old 07-11-2015, 01:41 PM   #2
I think it will look nice. Also you might looking into getting some graphics for it.
Old 07-11-2015, 01:42 PM   #3
dayves's Avatar
What do you mean graphics?? Like decals??
Old 07-11-2015, 01:43 PM   #4
Maybe some stripes.
Old 07-11-2015, 01:45 PM   #5
dayves's Avatar
I've thought about strips but that seems like a common thing, an I'm not sure I really like the look :/. I've been trying to think of things you never really see so make it unique
---------- Post added at 07:45 PM ---------- Previous post was at 07:45 PM ----------
Do you think some high quality spray paint would be good to paint the weather stripping with??
Old 07-11-2015, 02:02 PM   #6
Well there's rarely anything that hasn't been thought of that's been done to a car. I'd be surprised if no one has thought of your trim. Maybe not in your color combos. So the trick is to make it your own. Personally, I like the hockey stripes and I think it would look good on your car. But then again how will it go with the painted trim? I couldn't tell you. Basically, you have to picture what it might look like and if you like try it for real. Another thing to consider is possible putting louvers on it. That's what I'm doing with my car; picture what I want then try it.
As for application, I'd probably use a paint paint gun.
Old 07-11-2015, 02:05 PM   #7
dayves's Avatar
Rear window louvers or side windows??
Old 07-11-2015, 02:06 PM   #8
Take your pick, or maybe both.
Old 07-11-2015, 02:12 PM   #9
dayves's Avatar
I've always looked at rear louvers
Old 07-11-2015, 02:13 PM   #10
I've got them for mine but I'm still debating on it.
Old 07-11-2015, 02:35 PM   #11
dayves's Avatar
It gives em a bit meaner look in my opinion
Old 07-12-2015, 08:32 AM   #12
dwbrand's Avatar
I like the new rims, they look great!
Rear louvers look great if you ask me, I don't care for sides ones until you get 05 and newer (or the classics)
2003 Ford Mustang GT
1995 Ford F150 XLT 4x4
1968 Mercury Cougar
dwbrand is offline   Reply With Quote
Old 07-12-2015, 08:51 AM   #13
oxford5pointoh's Avatar
Is it me op or does your front wheel sit further back in the wheel well then it should?
IG @Oxford5pointoh
Old 07-12-2015, 08:52 AM   #14
dayves's Avatar
Me too, I was a little Leary when picking em up but I don't think I could be happier now.
---------- Post added at 02:52 PM ---------- Previous post was at 02:51 PM ----------
I was looking at that yesterday actually, an I can't tell if it does or not.
Old 07-12-2015, 08:53 AM   #15
Has it been in an accident?
IG @Oxford5pointoh
Old 07-12-2015, 08:54 AM   #16
dayves's Avatar
I was thinking it could be the angle the picture was taken along with the fact I don't have the plastic piece that goes in the wheel well to stop all the mud and water, but I'm not sure
---------- Post added at 02:54 PM ---------- Previous post was at 02:54 PM ----------
It had before I bought it
Old 07-12-2015, 08:55 AM   #17
Yeah maybe your right.
IG @Oxford5pointoh
Old 07-12-2015, 08:56 AM   #18
dayves's Avatar
If it is a little further back what would cause that?? And would it cause any problems??
Old 07-12-2015, 09:04 AM   #19
Lots of things could cause it mainly an accident that bent something. I've never messed with a new edge suspension but you might just want to visually inspect the lower control arm and the strut and make sure nothing looks messed up. You ave that other new edge, maybe take a measurement from the center of the wheel to the edge of the fender on both and see what you come up with.
Could also be the front bumper making it look that way. Have you changed it with an aftermarket one? Maybe it's just shaped differently.
If it is bent or messed up obviously it isn't good. Wears tires, makes noises but probably isn't safe most importantly.
IG @Oxford5pointoh
Old 07-12-2015, 09:05 AM   #20
dayves's Avatar
I just checked, there's a little more space between the fender and the tire on the left side than there is the right side.
Old 07-12-2015, 09:08 AM   #21
Rapinator126's Avatar
Something is bent. You can tell it's been in a wreck from the way the body panels line up in front. But just look everything over and replace whatever is damaged.
Old 07-12-2015, 09:08 AM   #22
dayves's Avatar
Name:	ImageUploadedByMustang Evolution1436713701.395043.jpg
ID:	186961while down there I noticed this, what could that be leaking??
Old 07-12-2015, 09:09 AM   #23
Could also be worn out bushings. I'd check out the suspension man.
IG @Oxford5pointoh
Old 07-12-2015, 09:10 AM   #24
dayves's Avatar
Okay, I'll definitely get under it soon and check what's going on. What if nothing's bent?? Because I've never noticed anything before an ice been under plenty of times.
Old 07-12-2015, 09:11 AM   #25
dayves's Avatar
I'll check bushings as well
Old 07-12-2015, 09:11 AM   #26
Attachment 186961while down there I noticed this, what could that be leaking??
Oil leaks always come from top to bottom front to back. So if it's only on the front of the oil pan it could be the oil pan.
IG @Oxford5pointoh
Old 07-12-2015, 09:13 AM   #27
I'd jack it up and try moving the suspension around to see if you have any play.
IG @Oxford5pointoh
Old 07-12-2015, 09:17 AM   #28
dayves's Avatar
My only delima is that I've moved 2 weeks ago and don't have my jack with me anymore so I gotta wait until I can go get one.
Old 07-12-2015, 09:21 AM   #29
I hear ya. Well I'd do it as soon as you can.
IG @Oxford5pointoh
Old 07-12-2015, 09:23 AM   #30
dayves's Avatar
I will, I wanta get whatever's f***** up fixed. And what do y'all advise for shocks and struts??
Old 07-12-2015, 09:54 AM   #31
dwbrand's Avatar
Does it drive ok? Wouldn't that be a dead giveaway to a problem if it didn't?
1968 Mercury Cougar
Old 07-12-2015, 09:57 AM   #32
Sometimes these things happen over time and they don't slap you in the face. But yeah seems like it would pull or shake.
IG @Oxford5pointoh
Old 07-12-2015, 09:57 AM   #33
dayves's Avatar
It drives great, that's what's weird. It drives perfectly straight if I take my hands off the wheel an it's smooth.
Old 07-12-2015, 01:03 PM   #34
dayves's Avatar
Ideas on parts and ideas for mods Mrsnow 1996-2004 Mustang GT 6 01-27-2012 01:13 PM
Minor Customizing JTeel1781 2005-2010 Mustang GT 8 01-22-2012 12:40 AM
new here, need help customizing jake2011stang New Member Introductions & Greetings 10 12-03-2011 03:30 AM
another "dont" when customizing a stang Kyle The Bar 10 06-16-2005 12:46 PM
Customizing Your Guages. Dom Mustang Audio & Video 10 04-14-2004 09:51 AM
» Members Mustangs
50 Stang
Beamer
Sasha
Nyke
Add your Mustang
09:30 AM
