4.10 - Mustang Evolution
Old 07-13-2015, 02:09 AM   #1
joe_117's Avatar
4.10
So my next mod will be gears. Been told its a must. Anything i should have checked before i have them installed?
Dont want anything to go wrong when they are installed.
joe_117 is offline   Reply With Quote
Old 07-13-2015, 02:12 AM   #2
joe_117's Avatar
Specs
01, tr3650 manual
Mods:
X4 tune with mpt
Bassani x pipe
Slp
---------- Post added at 08:12 AM ---------- Previous post was at 08:12 AM ----------
Mgw shifter^
Old 07-13-2015, 02:17 AM   #3
natestang07's Avatar
Just make sure to by frpp and not motive
Old 07-13-2015, 08:43 AM   #4
Yeah make sure the shop isn't charging you something like $600 plus parts to do it... Have MPT recal your speedo for the 4.10s. You are the 01 transmission so you likely still have the .68 overdrive which is not as deep as the 02-04 cars but still will be fine with 4.10s, people make way too big a deal about highway RPM because they want to do like 90mph all the time.
Old 07-13-2015, 12:45 PM   #5
infamous281's Avatar
Actually motive makes ford gears so it doesn't matter.
Just take it to a shop , they will let you know if you need anything.
If anything you can just install them without anything else , besides gear oil , crush sleeve , and a other part I forgot.
Usual shop install is 200-300
Sent from my SM-N910T using Mustang Evolution mobile app
Old 07-13-2015, 12:48 PM   #6
So why do I see so many issues with motive and not frpp? I didn't realize motive made them.
Old 07-13-2015, 12:52 PM   #7
It wasn't the Motives ppl had issues with, it was Richmond. Honestly if the OP was a 02-04 GT with the .62 overdrive I'd say get a set of taller rear tires and run 4.30s. What my plan was with that 98 before I sold it...
Old 07-13-2015, 01:07 PM   #8
Damn that's my bad. I should probably check before slandering companies lol
Old 07-13-2015, 02:05 PM   #9
joe_117's Avatar
So buy the frpp? I was going to order the complete 4.10 gear set on Latemodel
Old 07-13-2015, 02:08 PM   #10
joe_117's Avatar
This.
Name:	ImageUploadedByMustang Evolution1436818099.376726.jpg
Old 07-13-2015, 04:06 PM   #11
Would be a good idea to get the diff rebuild kit and have that done at the same time. The shop i went to didn't charge any extra labor for the diff rebuild.
Old 07-13-2015, 06:11 PM   #12
Slater2111's Avatar
I rebuilt mine as well while I was in there. I also did the axle tube bearings.
Sent from the mothership.
Slater2111 is offline   Reply With Quote
Old 07-14-2015, 01:54 PM   #13
WJL
I would go with the FRPP bearing kit rather than the motive, i think the kit you listed from LMR has the GT 500 Pinion bearing and that's what you want.
If i would do it over i would go with that kit or just go to NAPA and buy the bearing separate there is absolutely a difference, you can see and feel the weight difference, even the bearing cage is stronger.
You are going to want to pickup an additional shim kit as well, oh you will need another bottle of RP too.
JMO
WJL is offline   Reply With Quote
12:11 PM
