Front suspension rattle - Mustang Evolution
Old 07-13-2015, 10:41 PM   #1
keeney35's Avatar
So I've had the longtubes installed for a week or so now.
I had to disassemble basically the entire front suspension, drop the k member and all of that.
Now I'm noticing a rattle noise when I take a hard right turn, it's coming from the front passenger side and sometimes I hear it when I am coasting up to a stop sign or red light.
Any ideas?
I haven't got an alignment or anything checked so that may be part of it and I might need new ball joints.
I torqued everything down pretty tight on the suspension, but I'm gonna take it to a shop tomorrow and have them look it over and if something needs replaced I'll just order some performance and better replacements
keeney35 is offline   Reply With Quote
Old 07-14-2015, 07:41 AM   #2
Project Pony's Avatar
Could be the ball joint on that side. I've heard them clunk, bang, screech and scream in the 94-09 body styles. If you think you need ball joints then your probably way past due. It's always good practice to replace suspension parts before they let you know they are done.
[SIGPIC][/SIGPIC]
Old 07-14-2015, 09:36 AM   #3
keeney35's Avatar
There isn't really a performance version is there? Like mmr or anything?
Old 07-14-2015, 09:48 AM   #4
Steeda X2 ball joints off AM
Old 07-14-2015, 12:37 PM   #5
Soccer beat me to it. Those are the best balljoints for these cars, period. And they're not too expensive either.
Old 07-14-2015, 12:52 PM   #6
keeney35's Avatar
They can't get me in until tomorrow but I'm gonna have then look it over and I'll order those then
Old 07-14-2015, 04:12 PM   #7
keeney35's Avatar
Well I'm hearing it more frequently now.. And it sounds more like the rear now that I'm hearing it more frequently.
Are all the 99-04 gt's quad shock in the rear?
Old 07-14-2015, 07:46 PM   #8
keeney35's Avatar
My GT only has 2 shocks in the rear, one on each side.
I'm looking on am at the springs which ones should I be looking at
Are these koni's any good?
Name:	ImageUploadedByMustang Evolution1436924724.410027.jpg
Old 07-14-2015, 07:47 PM   #9
Koni is one of the best brands out there. They are only 2 shocks out back. There are "quad shocks" but its not what you are thinking. Quad shocks are little shocks in the wheel well that attempt to keep the crappy stock 4 link from being too bad.
In all honesty, the SR springs AM sells are not bad at all. They're the only SR product I would put on a car I owned.
Old 07-14-2015, 08:16 PM   #10
keeney35's Avatar
Well I'll go ahead and get the koni's if that is what I'm hearing rattle..
What else good it be? When they go bad is that one of the symptoms
Old 07-14-2015, 08:16 PM   #11
dayves's Avatar
Is it bad to replace shocks without replacing your struts??
dayves is offline   Reply With Quote
Old 07-14-2015, 09:24 PM   #12
Well its not going to hurt anything but you really should do it all at once if you can. Also, Keeney, make sure you've isolated the issue before just throwing parts at it.
Old 07-14-2015, 09:57 PM   #13
keeney35's Avatar
I am that's why I'm gonna wait and see what they say tomorrow
Old 07-14-2015, 11:39 PM   #14
Steve96's Avatar
I have the same konis your looking at and their great. Fyi
1996 GT
Old 07-15-2015, 12:05 AM   #15
keeney35's Avatar
If it's ball joints I'm going steeda, anything else max motorpsorts most likely
Old 07-15-2015, 12:06 AM   #16
Steve96's Avatar
Steeda x2s make it a slight bit lower too, dont they?
1996 GT
Old 07-15-2015, 12:39 AM   #17
keeney35's Avatar
Idk I'm already lowered lol
Old 07-15-2015, 05:55 AM   #18
Only if you leave out the included spacers. If you install the spacers it maintains whatever ride height you are at although you'll need a front end alignment with new balljoints.
Old 07-15-2015, 12:36 PM   #19
keeney35's Avatar
Okay, both rear shocks are shot, covered in oil and grime.
The passenger inner tie rod is bent, and the drivers has play as well.
So I'm going to get the koni shocks, and new inner tie Rods, should i get new outers too?
Old 07-15-2015, 01:11 PM   #20
dwbrand's Avatar
I would. If you have to get an alignment, might as well make it worth it.
2003 Ford Mustang GT
1995 Ford F150 XLT 4x4
1968 Mercury Cougar
dwbrand is offline   Reply With Quote
Old 07-15-2015, 01:17 PM   #21
keeney35's Avatar
I went ahead and ordered Click image for larger version
Name:	ImageUploadedByMustang Evolution1436987872.255258.jpg
So hopefully that takes care of the rattle and any issues I've had that haven't noticed.. From what I hear the shocks are gonna make a huge difference
Old 07-15-2015, 03:55 PM   #22
Looks good. Hopefully those prices on the rods are comparable with Rockauto and Amazon. I have not checked recently... Either way, you got what you need.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 07-15-2015, 04:14 PM   #23
keeney35's Avatar
They were 5$ on rock auto but didn't know if I could trust it or not lol
Old 07-15-2015, 05:34 PM   #24
Eh... It was probably some no name brand. I usually go with moog on Rockauto.
Rattle in front end JWorm 1996-2004 Mustang GT 2 07-19-2014 04:41 PM
Exhaust rattle/front end noise Torchred2010gt 2005-2010 Mustang GT 14 04-26-2014 11:45 PM
2006 GT Front-end Rattle luangtom 2005-2010 Mustang GT 3 12-19-2012 02:33 PM
06 Rattle/ Squeak in front. 99ford Pre-2005 V6 Mustang 3 02-10-2010 08:09 PM
Dash Rattle?? Tranny Rattle?? ricklmesa Pre-2005 V6 Mustang 0 03-08-2006 07:19 PM
07:37 PM
