P0190 Driving me nuts - Mustang Evolution
Old 07-14-2015, 02:28 PM   #1
Hi everyone as you can see im new to here 😀 , seems like a great community as I've used the forums but never actually signed up but now I found myself here 😄
Anyways sometime last week was giving my car hell on the road and check engine light came on and I pulled over just to check it and it came up p0190 so I figured it was the p0190 bought a fprs and cleared the code. The car hasn't ran right since the code first popped up its like its not making power like it was the code was not on earlier today but I checked once more before I went into work and she is still there once again 😢 any ideas or tips ?
Skax is offline   Reply With Quote
Old 07-14-2015, 02:33 PM   #2
Kevin.Cook
Guest
Posts: n/a
Isnt that code for fuel rail pressure sensor? Are you tuned? if not, it might need replaced.
Old 07-14-2015, 02:34 PM   #3
jeno's Avatar
Yes or even a possible vacuum leak
Sent from my Nexus 6 using Tapatalk
jeno is offline   Reply With Quote
Old 07-14-2015, 02:36 PM   #4
Yea probally would've helped if I listed mods
2002 Mustang GT
Procharger P1SC Supercharger, 8psi
Procharger Intercooler, Headers,
Borla Off Road X-Pipe Exhaust, Mass Airflow
Upgraded Fuel Injectors
SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Old 07-14-2015, 02:38 PM   #5
Kevin.Cook
Guest
Posts: n/a
oh wow. Might have failed then. Is everything showing crazy? Such as afr and stuff.
Old 07-14-2015, 02:38 PM   #6
jeno's Avatar
Well your code is this
Possible causes
- High fuel pressure
- Low fuel pressure
- Damaged FRP sensor
- Excessive resistance in the circuit
- Low or no fuel
- Wiring harness connector of the fuel pressure sensor
- Fuel Rail Pressure Sensor
- Vacuum leaks
- Fuel
Read more:*http://engine-codes.com/p0190.html#ixzz3ftsiMwtA
Old 07-14-2015, 02:39 PM   #7
Kevin.Cook
Guest
Posts: n/a
Well if those are possible suspects. I would start with the easiest fixes. Checking for vacuum leaks, using some good quality fuel system cleaner, etc.
Old 07-14-2015, 02:48 PM   #8
Grabber Blue5.0's Avatar
Are you running a BAP by any chance?
Old 07-14-2015, 02:50 PM   #9
https://imagizer.imageshack.us/v2/94...661/WSCSUU.jpg
Old 07-14-2015, 02:53 PM   #10
Fuel pressure is fine no vacuum leaks maybe just another bad fprs by any chance and idk about the bap?
Old 07-14-2015, 02:54 PM   #11
jeno's Avatar
Possible bad fpr
Old 07-14-2015, 04:50 PM   #12
Here's my data log results if this narrows it down any
Old 07-15-2015, 09:24 AM   #13
Steve96's Avatar
Their too small to read
1996 GT
Japan is driving me nuts! Polar Bear General Mustang Discussion 0 04-17-2014 10:19 PM
Door lock driving me nuts! Arron's racecar 1996-2004 Mustang GT 1 04-09-2013 02:49 AM
No Power Driving Me Nuts!!! v8pony The Bar 6 10-29-2012 09:38 PM
P0190 DTC HELP! MiGT01 1996-2004 Mustang GT 5 03-18-2012 06:37 AM
Code P0190 PLEASE HELP CodyNelson 1996-2004 Mustang GT 0 01-27-2012 07:43 AM
06:56 AM
