Still running rich at WOT! - Mustang Evolution
Old 07-14-2015, 07:25 PM   #1
So originally on my 01 gt I had just removed the cats, welded on some new pipes. Ever since then I noticed the car runs super rich only when she's hot. I ended up getting a whole new exhaust last week because the old one was so shot. Runs alot better but still the same issue at wot. I bought mil eliminators and they're doing their job. So after all of this being done and resetting the ecu correctly about three times now, I'm starting to come to the conclusion that my car goes from open loop when she first starts cold, to closed loop because everything runs normal when it's warm but not too warm, to open loop again. Would it be the o2 sensors not heating up enough and causing it to go into dummy mode again? I have not replaced the rear exhaust o2 sensors since I bought it last fall. Ive replaced plugs and boots last fall. Cleaned the Maf sensor twice now. I think the only mod I've been able to afford is the exhaust and a bbk intake D: Any help would be awesome. I really just don't have the money to take it anywhere. And I wouldn't want to do that in the first place... also wondered if a cop could go bad when it gets too hot. I've
Metered all of them but they seem to be all good. Thanks guys. P.s. I know it's not oil or antifreeze, and that it's definitely abnormal. I understand that removing cats will make everything more fumy. But not a big cloud when you take off from a light lol.
Sent from my SM-G900P using Mustang Evolution mobile app
hades1346 is offline   Reply With Quote
Old 07-14-2015, 10:06 PM   #2
The first thing that you should do is scan the car for any trouble codes.
Most auto parts stores can do this for you.
Old 07-15-2015, 08:18 AM   #3
The only one that comes up is evaporative emissions because of the faulty gasket by my gas tank.
Old 07-15-2015, 02:31 PM   #4
You should repair that, but I don't think that would cause the symptoms that you described.
How many miles are on the car?
Do you think that the upstream 02 sensors are original?
What color is the smoke, after idling for a few minutes?
Old 07-18-2015, 01:32 PM   #5
Speed_Mister's Avatar
Region: Arkansas
If you have O2 extensions replace them, if not replace O2 sensor, if that doesn't work replace O2 wire harness.
2004 Mustang GT 5 Speed Full Bolt On 370rwhp 440rwtq
---------- Post added at 02:32 PM ---------- Previous post was at 02:32 PM ----------
I had the same problem and it was an extension.
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Why can't the rich just be happy, with being rich? esra General Car Discussion 20 07-16-2015 03:14 PM
Running to Rich Mustang_Madness 1996-2004 Mustang GT 3 01-29-2012 06:12 AM
3.8 Running Rich mu_stang Pre-2005 V6 Mustang 4 02-10-2011 04:43 AM
87 Mustang has very high idle and running VERY rich. Any ideas? clannan1 1979-1995 Mustang GT 5 08-21-2010 11:25 AM
I'm RICH!!!! I'm RICH!!!! PureVenom 1996-2004 Mustang GT 34 04-23-2009 09:23 AM
08:21 PM
