EGR System - Mustang Evolution
Old 07-16-2015, 12:07 PM   #1
Michael.s.king's Avatar
Region: Maine
EGR System
Can anyone tell me how to test specific parts of your EGR system?
I think some thing is messed up, but not sure if it is the valve, the sensor, or whatever.
Michael.s.king is offline   Reply With Quote
Old 07-16-2015, 10:17 PM   #2
keeney35's Avatar
Just delete it. All it will do is throw a code, plus it cleans up the engine bay
keeney35 is offline   Reply With Quote
Old 07-17-2015, 05:23 PM   #3
WJL
There are three basic components of the EGR System , excluding the PCM and the engine coolant temperature sensor, TPS and a couple of other things
The EGR Valve itself which is vacuum controlled, the Vacuum Regulator electrically controlled and the DPFE Sensor (Differential Pressure Feedback EGR) which is also electrically controlled.
To check the EGR valve you will need a vacuum pump, you will have to remove the egr tube or the valve itself to see if the valve opens when you apply vacuum if it moves smoothly all is good.
To check the vacuum regulator "T" pin either of the two wires, it doesn't matter which wire you check it is ground side controlled by the PCM turn the key on and check for battery voltage if you have 12V you have power, if you have power check the resistance of the regulator it should have somewhere between 30 and 70 ohms if it does all is good.
The DPFE Sensor is a little different it is a three wire connector you need to find the reference voltage wire check it on the harness side with DMM on DC volts it should have 4 to 6 volts with the key on engine off.
Also check the signal voltage to the sensor, back probe the correct wires (Signal and Ground wires)and check for voltage while the engine is running first cold and again when warm when cold there should be no signal and should be 0.20 to 0.70 volts as the engine gets warm the voltage should increase to 4 to 6 volts.
This in no way is all inclusive but if you have a little experience you should be able to do these checks.
Good luck, nothing ventured nothing gained. Worst case Google
WJL is offline   Reply With Quote
Old 07-17-2015, 05:24 PM   #4
joe_117's Avatar
If you delete it it will be fine with a tune right?
joe_117 is offline   Reply With Quote
Old 07-17-2015, 05:28 PM   #5
WJL
yes but that's too easy, also not 49 state legal but what the Hell does that mean anyhow
Old 07-17-2015, 05:39 PM   #6
Slater2111's Avatar
I didn't buy a muscle car to "save the environment!"
Sent from the mothership.
Slater2111 is offline   Reply With Quote
Old 07-17-2015, 05:55 PM   #7
WJL
Don't get me wrong i think rolling coal is COOL i hope all these hybrid save all the gas so i have more to burn, in fact since it finally has quit raining here i'm going for a Friday night ride and will be burning fuel and rubber, SEE YA
Old 07-17-2015, 10:12 PM   #8
joe_117's Avatar
So what does the EGR delete do?
Old 07-17-2015, 10:23 PM   #9
keeney35's Avatar
Cleans the engine bay up doesn't really have any cons you might see an drop in mpg like .5 mpg at cruising speeds
Name:	ImageUploadedByMustang Evolution1437189677.047798.jpg
That's what all you can remove in the delete
Here's the after pic of the engine bay
Name:	ImageUploadedByMustang Evolution1437189741.931496.jpg
ID:	187403Click image for larger version
Name:	ImageUploadedByMustang Evolution1437189754.870086.jpg
Old 07-17-2015, 10:24 PM   #10
keeney35's Avatar
Also I don't have a tune so it's not hurting anything without one, but if you get a tune you can turn it off and it won't hurt your mpg
Old 07-18-2015, 07:19 PM   #11
WJL
No check engine light?
Old 07-18-2015, 09:58 PM   #12
keeney35's Avatar
EGR System
I have a check engine light but idc cause it's on anyways from my cats being deleted. I've got a code reader so I just check it once a week to make sure it's nothing else.
We drive mustangs so do we really care about the environment and having legal exhaust? Lol
stock sound system vs. shaker audio system (2014 Mustang) Charlesph55 Mustang Audio & Video 6 02-15-2017 07:11 AM
Eibach Pro-System-Plus vs. Eibach Sport-System-Plus MustangGT02 1996-2004 Mustang GT 15 01-12-2013 03:45 PM
need opinions on new sound system for 98 cobra with Mach system tennisfreak802 Mustang Audio & Video 7 04-28-2010 02:29 PM
EGR flow insufficent el cheapo Pre-2005 V6 Mustang 2 04-25-2004 12:04 PM
EGR flow insufficent (repost of thread in ECU) el cheapo Pre-2005 V6 Mustang 5 12-04-2003 01:08 AM
06:20 PM
