front suspension squeak and thumbing - Mustang Evolution
Old 07-19-2015, 12:13 AM   #1
robin_gt's Avatar
Hey folks,
So i just got back from the drag strip and noticed when i go lower speeds (20-40mph) i can feel a thumbing (almost like if the wheel was not completely round, like an egg you get what im trying to say) but cant hear it from the front suspension, i suspect it being something in the passenger side suspension, i dont feel it going highway speeds. Also every little bump i hit on the road makes a squeaking sound which drives me absolutely nuts
So today i have had enough of the squeaking, tomorrow i am taking apart the front suspension and taking a close look at everything, i already tightened the strut nut which i had a squeaking problem with a couple months ago and it was just loose, i also tightened all the bolts on my caster camber plates, both did not help at all with the squeaking this time. When i drop the front suspension i am also taking out the springs to tape the ends up, should i use electrical tape or duct tape?
What are some common squeaking causes on the front suspension?
Thanks alot.
robin_gt is offline   Reply With Quote
Old 07-19-2015, 01:06 AM   #2
infamous281's Avatar
Could be ball joints .. end links .. running with no iso .. strut mounts .. depends on what you find when you really take a look at it.
Electric tape is fine
Sent from my SM-N910T using Mustang Evolution mobile app
Old 07-19-2015, 01:18 AM   #3
robin_gt's Avatar
thanks for the reply
ok imma use black electrical tape for the springs tomorrow and i am going to closely inspect/move the suspension components in order to track down that squeak, i doubt its the ball joint because i replaced them like 5 months ago with the autozone brand duralast or some **** like that, maybe the ball joints are dry and just need grease? there is no movement at all if i have the car in the air and try to wiggle the wheel
Old 07-19-2015, 03:36 PM   #4
Try the tape , it may help if there is no iso on the springs.
« EGR System | Shocks »
Suspension squeak legends51 1996-2004 Mustang GT 4 05-14-2014 09:43 AM
Squeak from front driver side Rich04 1996-2004 Mustang GT 13 03-06-2013 07:02 PM
Suspension squeak 1gt289 Pre-2005 V6 Mustang 14 07-22-2012 06:00 PM
06 Rattle/ Squeak in front. 99ford Pre-2005 V6 Mustang 3 02-10-2010 09:09 PM
squeak noise from front of engine. Blkness General Mustang Discussion 3 09-14-2009 09:29 PM
» Members Mustangs
Cool One
GTGirl
Boss
BOSS702
Add your Mustang
06:31 AM
