Big suspension upgrades - Mustang Evolution
Old 07-19-2015, 12:08 AM   #1
keeney35's Avatar
So I just got new shocks for the rear, and new inner and outer tie rods..
I watched some install videos on YouTube that CJponyparts did and American muscle too. I can't remember which company said it, I thought it was CJ but I swear the mentioned you can order suspension stuff in a red powder coat or red color like the lower control arms and subframe connectors so is this true does someone offer them in color or do people get them powder coated themselves?
Lots of guys I know have red suspension items all over there cars.
Also right now the only suspension mods I have are caster camber plates, steeda lowering springs 1.5", koni shocks in the rear, and a front strut bar..
So what's the most important to start with?
I was gonna get
mm subframe connectors
Lower control arms
Steeda x2 ball joints
Koni struts up front to match the rear
Then I didn't know what else I should get, some eibach roll bars? New k member?
keeney35 is offline   Reply With Quote
Old 07-19-2015, 12:43 AM   #2
Steve96's Avatar
Panhard bar?
1996 GT
Old 07-19-2015, 08:25 AM   #3
BLKBETTY13's Avatar
BMR
BLKBETTY13 is offline   Reply With Quote
Old 07-19-2015, 08:26 AM   #4
keeney35's Avatar
I was reading some old threads and someone was saying you could remove the quad shocks once you upgrade the lca's and get a panhard bar because it's essentially a 3-link
Old 07-20-2015, 05:28 PM   #5
Originally Posted by BLKBETTY13 View Post
BMR
Why would you recommend a company that only makes 05+ parts?
You CAN remove the quads but I'd leave them in with the 4 link setup in place unless there is some reason like a huge wheel where they'd have to come out.
Once you put in a PHB you can remove them as well if you want. A "poor man's 3 link" is a PHB installed and one UCA removed.
Old 07-21-2015, 10:44 PM   #6
Ideally you would want to change the other UCA also to one with a rod type bushing you would find on a Panhard bar, and you also need to have battle boxes welded in to brace the UCA (if it is this route, remove the driver side). That is if you go with the PM3L. I vote Torque Arm. Its worth the weight, and it's added to the rear so it helps the balance. Even Brett Madsen is finally swapping his PM3L to a Torque Arm.
Old 07-21-2015, 10:51 PM   #7
1. MM Subframe connectors
2. MM Rear Lower control arms
3. MM Panhard Bar OR FTR Watts Link
4. MM Torque Arm OR Poor Man's 3 Link
5. Adjustable Sway Bars (Preferably MM)
Those parts in that order. Basically the only way it SHOULD be done.
A new k member usually requires the addition of the A arms as well as coil over conversion. if you go with MM then they also need a few other items relating to the steering rack. So save that until you get the important stuff done.
Old 07-22-2015, 03:47 AM   #8
thyreaper's Avatar
What are the things pertaining the rack? I wasnt aware of this and im planning to make the leap soon from stock k member to the mm one
thyreaper is offline   Reply With Quote
Old 07-22-2015, 09:53 AM   #9
Their bushings and the bolt through bumpsteer kit among a few other things like the oil filter relocation kit. Honestly once you get the MM front K setup fully installed and everything it isn't too much more to go Griggs and Griggs has provisions for a front SLA setup although that is getting a little crazy unless you are all out road racing. And your class allows it... Actually its about the same price for both systems if you don't need the Griggs severe duty front arms which 99% of ppl won't.
Old 07-22-2015, 10:40 AM   #10
On MM's website it says everything needed.
http://www.maximummotorsports.com/MM...2004-P276.aspx
Old 07-22-2015, 01:47 PM   #11
Soccer are you dead set on the MM for yours? I just checked the Griggs site for the first time in literally over a year and it's not as expensive as I remember. Or I just don't remember right lol.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 07-22-2015, 03:15 PM   #12
The K member i was going to do Griggs, that way i can do the lower control arm that is upgradable to SLA later on. Both of those things combined though is $1800 lmao. Except with everything thats been happening lately i can only really afford to pull out $20 per week and set that aside toward mods lol. So nothing major happening soon. Just minor stuff. Might do that aluminum coolant expansion tank soon, powder coated black. Lethal has one already coated.
What Suspension Upgrades? helloWorld 2011-2014 Mustang GT 8 08-18-2012 09:28 AM
Suspension Upgrades? mchilliard28 Pre-2005 V6 Mustang 4 03-04-2012 03:33 AM
Exterior upgrades and maybe performance upgrades RedToplessPony 2011-2014 V6 Mustang 34 12-26-2011 04:09 PM
68 suspension & brake upgrades? Jpeverini Classic Mustangs 14 07-06-2008 09:44 PM
Break down upgrades to suspension in STAGES for me please! ASSEMbler Pre-2005 V6 Mustang 27 12-26-2003 10:39 AM
09:35 AM
