Tie rod replacement - Mustang Evolution
Old 07-20-2015, 03:30 PM   #1
keeney35's Avatar
Tie rod replacement
I got new inner and outer tie rods
How do I need to remove them and such? What all comes off first or can I just remove them and nothing else?
I'll have jack stands and an impact so I've got the tools but do I need to count threads or anything?
I'll also be getting an alignment probably this weekend
keeney35 is offline   Reply With Quote
Old 07-20-2015, 04:12 PM   #2
Yes.
You want to either count the number of turns that it takes to separate the old inner and outer tie rods, or take measurements, so you can put each side together as close as possible to how it was.
You will undoubtedly need an alignment afterwards, but those methods will usually get the alignment close enough to be able to drive the car to the alignment shop.
Old 07-20-2015, 04:19 PM   #3
And you can just remove the tie rods and nothing else, but I would also replace the steering rack bushings while you're at it. You just need to disconnect the steering rod and remove the two bolts holding the rack on. You can pull it away from the crossmember without disconnecting the power steering lines.
Old 07-20-2015, 05:00 PM   #4
keeney35's Avatar
I got my new shocks put on but I think I'm just gonna let a shop throw them on when I get my alignment, I ordered new bushings too.
I know it needs an alignment after I dropped the k for the headers, and my passenger tie rods bent to hell from something the previous owner did.. But it should at least be able to get me around until j get the alignment this weekend or so..
Also this may be a dumb question but do I need to get a front and rear alignment or just the front?
Old 07-20-2015, 05:03 PM   #5
keeney35's Avatar
The old shocks were horrible Click image for larger version
Name:	ImageUploadedByMustang Evolution1437433309.193301.jpg
ID:	187608Click image for larger version
Name:	ImageUploadedByMustang Evolution1437433321.882460.jpg
New koni's are in and it already feels better, so much stiffer and the *** end feels a lot more in controlClick image for larger version
Name:	ImageUploadedByMustang Evolution1437433360.035112.jpg
ID:	187610Click image for larger version
Name:	ImageUploadedByMustang Evolution1437433395.119080.jpg
Old 07-20-2015, 05:11 PM   #6
Mile high JDF's Avatar
You'll be fine with a 2-wheel alignment. The only reason for a 4-wheel on a SRA car is to check the axle thrust angle.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 07-20-2015, 05:12 PM   #7
Yeah. When the rear shocks are bad, it is really noticeable!
There isn't any way to adjust an SRA, so they will only be able to do a front end alignment.
Old 07-20-2015, 06:27 PM   #8
keeney35's Avatar
Yeah the rears were horrible, but it has tokico shocks which were put on when it was lowered and that wasn't very long ago, just before I bought it, I would stay away from those for future reference guys
Old 07-20-2015, 09:00 PM   #9
I had Tokicos on the 98 and they were great.
Old 07-20-2015, 09:07 PM   #10
jeno's Avatar
Maybe because they weren't made for lowering springs
Sent from my Nexus 6 using Tapatalk
jeno is offline   Reply With Quote
Old 07-20-2015, 09:17 PM   #11
The Tokicos I had were the Illuminas btw and I never touched them because I never needed to. Apparently they were adjustable and the PO had them set up correctly because my ride felt damn near stock but the car was lowered.
Old 07-21-2015, 09:10 AM   #12
keeney35's Avatar
I never realized how bad the ride was until I got these new shocks on the rear lol but none the less in happy with the konis
Old 07-21-2015, 09:13 AM   #13
Yeah Koni is one of the best brands. For me, buying a new setup, its either them or Bilsteins.
Old 07-21-2015, 02:18 PM   #14
keeney35's Avatar
Next purchase will definitely be konis up front too, the on to subframe connectors and lca's
tie rod end replacement v8pony 1996-2004 Mustang GT 3 06-29-2013 10:15 PM
Purchasing Turn Buckle/tie rod OzzyLiriano 2011-2014 Mustang GT 0 09-05-2012 10:42 PM
Inner tie rod ends Justintriner 1996-2004 Mustang GT 2 12-10-2011 01:07 AM
Tie Rod Kamakanani0 Pre-2005 V6 Mustang 15 01-28-2011 08:10 PM
Tie Rod: Smokedya95stang Pre-2005 V6 Mustang 3 05-10-2004 10:29 PM
09:08 PM
