Need help gaining power! - Mustang Evolution
Old 07-24-2015, 01:05 PM   #1
Bellairs's Avatar
I'm looking to eventually push at least 340 in my 01 GT( currently have 270 with intake and throttle body) but i've been told that 4.6's are really hard to make power with so i've had a lot of different ideas on how to do it. That's why i'm asking that because i'm at too many crossroads on what to do. Anything honestly helps and money's not an issue, I work full time and am 18.
01 GT
Bellairs is offline   Reply With Quote
Old 07-24-2015, 03:14 PM   #2
The_Chech's Avatar
01 GT
Your best bet to get any thing over 300 and cheapest is to either run Nitrous or boost it. Don't bother with doing cams on a 2V because in all reality for almost the same amount of money you could of bought a Vortech off some one and made way more power. Quite a few even on this forum have gotten into a supercharger out the door for under 3K. If you get every thing your self second hand or some things even new you can do it for very cheap.
Hope this helps!
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Old 07-24-2015, 04:30 PM   #3
Speed_Mister's Avatar
Region: Arkansas
If you just have intake and throttle body you're more like at 230rwhp. Maybe 270 crank horsepower. It takes intake, throttle body, plenum, longtubes headers, mid-pipes, car back, under drive pulleys, and tune to make 260rwhp with heads and cam 300-320rwhp.. Full Bolt one will cost you maybe $2,500 and you can be at 300-320rwhp or you can just buy a supercharger kit for $4k or a nitrous kit for $600 and be at up to 400rwhp.
2004 Mustang GT 5 Speed Full Bolt Ons 385rwhp 450rwtq
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 07-24-2015, 08:00 PM   #4
keeney35's Avatar
Lol yeah if you are "370" with just 2 mods I want to see the car and dyno sheet.. I've got everything speed mentioned other than aftermarket heads and I'm only 364 rwhp if you have the money then get some kinda boost.. I'm building mine n/a first as much as I can and beefing the internals then gonna procharge it
keeney35 is offline   Reply With Quote
Old 07-24-2015, 08:09 PM   #5
01 GT
Let's clear up a few things.....
Engine power does not matter, just wheel power. You make 260 to the flywheel stock, so it's around 230 to the wheels stock. An intake and throttle body probably won't do anything if you don't have a tune, so your are most likely still around 230 to the wheel.
A full bolt on and tuned 4.6 2v usually makes around 260 to the wheels, anything more than that you basically need heads, cams, boost or spray.
Old 07-24-2015, 10:42 PM   #6
Region: Arkansas
Should have all the info you need we said which way is cheapest and how to achieve your goal. 👍🏼 good luck
Full Bolt Ons
370rwhp 470rwtq
Old 07-25-2015, 01:57 AM   #7
Bellairs's Avatar
Yeah I wasnt talking rwhp by the way and everything helped! Thanks! Quick question though, would it matter what bolt ons I get if I got a supercharger? Like would certain bolt ons have to be taken off because of it?
SN-95 New Edge GT
Old 07-25-2015, 11:18 AM   #8
phatspeed7x's Avatar
2004 Mustang GT
Airaid cold air intake
75mm throttle body and plenum
Pypes off-road H pipe
Flowmaster super 10 series
250rwhp
283 ft lb
Factory tune and 87 octane fuel.
O'Reilly street machine nationals dyno run (both): https://youtu.be/_M74OffhdB0
~2004 GT with Bolt ons~
phatspeed7x is offline   Reply With Quote
Old 07-25-2015, 11:54 AM   #9
keeney35's Avatar
Some cams work better with superchargers and nos and some stuff needs to line up but that's a question for the experts
Old 07-25-2015, 02:06 PM   #10
Bellairs's Avatar
What if I got a brand new 5.0 4V Engine? It's a solid 6,250$ for the engine and I can do the instal with my Dad in his garage. Is it worth saving every car savings dollar I make to get it within the year or next?
SN-95 New Edge GT
Old 07-25-2015, 02:09 PM   #11
Rapinator126's Avatar
STD #'s read high and mobile dynos almost always give out false #'s
Old 07-25-2015, 02:30 PM   #12
Mile high JDF's Avatar
SN-95 New Edge GT
Look up Soccerluvr4's coyote swap thread, it's been bumped fairly recently. A Coyote swap is gonna run in the $10k-$15k range pretty quickly but will be a badass ride when it's all said and done.
Being so young (and having had the same thoughts when I was that age as well) take the time to really hash out what you want out of the car and how realistically you think that can be achieved. Personally, before I even think about a coyote swap or a blower, I would take a serious look at my suspension and tires to make sure I can get the power to the ground.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 07-25-2015, 02:30 PM   #13
SN-95 New Edge GT
Yes.
Gears.
Supercharged, you'll want them to be close to the stock ratio.
Old 07-25-2015, 02:33 PM   #14
SN-95 New Edge GT
Yeah.
Double that $6250 and you will be a lot closer to the actual cost of the swap.
Old 07-25-2015, 03:03 PM   #15
My buddy Kirk has a procharger on his 01. Bought the head unit used for $900 and built the rest of the kit with random parts. Upgraded his fuel system. Motor already had cams and long tube headers. Once he had it all together and tuned the car makes 426rwhp.
Speed cost money. How fast can you afford to go?
Old 07-26-2015, 03:01 AM   #16
Bellairs's Avatar
Currently, i'm replacing a lot of the old suspension parts and i'm working on really caring for the car. Most of the replies really helped me make up my mind and realistically bolt ons and appearance mods will be my go to's. I'd rather have a ton of mods in the car over one single blower. I'll just keep messing around with the various small things that'll give me some gains and just enjoy my car until I get a newer 5.0(2-4 years from now). Any thoughts on apperance? So far I want chrome 19 Saleen's, blue stripes, and the roush bumper
SN-95 New Edge GT
Old 07-26-2015, 03:10 AM   #17
chrome 18 Saleen's and the roush bumper
SN-95 New Edge GT
Out of your list that's what I'd do but thats just my personal opinion. I'd do wheels, lower it, and slap a mach one lip on it
Old 07-26-2015, 03:30 PM   #18
Bellairs's Avatar
I have a Mach 1 Lip on it atm but my bumper has stress marks from an accident the previous owner got into which is why I want a new one
SN-95 New Edge GT
Old 07-26-2015, 09:35 PM   #19
Just ordered the Mach 1 lip and the super dark headlights from am. Have a spoiler delete as well as lowering springs. Also have those matte black fender stripes coming in. Just think lowered these cars look great and with the spoiler delete is just works with the body lines of the car.
wawanesa5speed is offline   Reply With Quote
Old 07-26-2015, 10:50 PM   #20
thyreaper's Avatar
Me personally id rathar have the blower and make 380-450 rwhp (pending on mods) then to have a bunch of stuff costing over 3k and still get clowned on by a stock ls1 car, a blower, some suspension and a good tire will put a smile on ur face everytime u get on it the sound and feeling of boost is orgasmic lol, im in a vortech kit and have everything i said but a good tire so i still spin 1-2 but 3rd pulls like a fright train, i barrowed a buddies mt et streets off his mustang and my car hooks on the street its fast enough that i can put a 100$ bill on dash and u prolly cant get it (with the et streets on it)
thyreaper is offline   Reply With Quote
Old 07-26-2015, 11:46 PM   #21
NewMtang's Avatar
01 GT
If money is not an issue, trade it in on a newer GT. 2013 and up.
Old 07-27-2015, 09:31 AM   #22
dwbrand's Avatar
I read last night a 3v head will bolt on to a 2v block, you have to change induction and a couple other things. Since the 2005 3v motor made 300hp stock, would that be a way to bump up a 2v motor?
2003 Ford Mustang GT
1995 Ford F150 XLT 4x4
1968 Mercury Cougar
dwbrand is offline   Reply With Quote
Old 07-27-2015, 10:15 AM   #23
It's a little more than just a head and induction swap. Computer sensors and tune will all have to be converted over. Also your getting into a cylinder head with spark plugs that like to break off in the head. I've seen more issues with that and phasers while working at Ford here.
I'd rather have a 2V all day long.
Sent from my SM-G900P using Tapatalk
Old 07-27-2015, 02:08 PM   #24
XSlashDashX's Avatar
Invest in the new 5.0 Mustang and call it a day.
Old 07-27-2015, 05:04 PM   #25
Boost or spray, I'd pick boost personally. Being nitrous has one major flaw, it runs out.
Pick your poison.
Old 07-27-2015, 06:06 PM   #26
What kind of mpg loss would you experience running a supercharged set up? Just planning the future of my car and how to make power out of its 2v. But my car will always be a daily driver with lots of highway miles.
Old 07-27-2015, 06:30 PM   #27
All in the tune.
Pick your poison.
Old 07-27-2015, 11:18 PM   #28
More air = more fuel.
With a supercharger mpg should stay around the same if you are out of boost. When you enter boost mpg goes down the toilet.
Old 07-28-2015, 07:33 AM   #29
"More power" out of a 2V=power adder.
Besides exhaust, gears and a tune... nothing else is really going to do anything for you NA in the power dept. Suspension is the big ticket thing with the 04-down cars that ALWAYS gets overlooked. Dunno how many "4x4" cars you see out there will all sorts of useless bolt ons and the dude driving it thinks he's fast as hell.
NA 2V mod list should really be:
-Mid pipe
-Catback
-Subframes
-Springs/shocks/struts
-CC plates
-4.10 or 4.30 gears
-Good set of wheels tires (Mickeys or BFGs)
-MPT 93 Octane (or 91 if that's all you can get) remote tune
-Add a wideband gauge if you have a tune
-Shifter for stick or a converter/jmod for auto
After that its either a power adder with a fuel system to support it or drive it as is. Cosmetics obviously are going to be subjective but just FYI, saleens are played out as hell and I would not recommend chrome rims for a daily driver.
It only takes a very few things to make a 99-04 car look GREAT and even the 94-98 cars can look really really good with the right exterior mods. My old blue 98 was one of the best looking 04-down cars I've ever seen and I'm not just saying that.
2000 Mustang GT Steeda #0048
Old 08-03-2015, 02:09 AM   #30
retiredvet's Avatar
with my setup I get 328 rwhp but I have 10.2:1 compression because I had my heads shaved a few thousands when I had them ported. I have a low mile spare block from a junk yard sitting in my garage I am getting ready to install a 5.3 stroker kit into I just picked up for 1100 bucks(forged everything except crank). No idea what to expect power wise from it but should add some serious torque.
03 GT 13.4 @ 117MPH best 2v 4.6 w/ auto
Check out my Garage info for what I am installing at this moment~
retiredvet is offline   Reply With Quote
Old 08-03-2015, 03:12 AM   #31
2011 Kona Blue's Avatar
01 GT
Just an idea but if you want more power just sell your current ride and step down 2 cylinders to the 3.7. The manual makes around 270 rwhp right from jump. 40 more rwhp than your current one and that's completely stock.
Sent from my SAMSUNG-SM-G890A using Mustang Evolution mobile app
Old 08-03-2015, 09:36 AM   #32
I have to agree with this and for the price they are at now... Sub $15k for a real nice 11/12 sixxer that is going to be much faster and get 30+mpg. The Cyclone is still overcoming the "lol v6 mustang" stigma from the previous generations and will be for some time even after it goes OOP for the Ecoboost. It is a crazy badass little engine and a 11+ V6 is a "GT" in any previous generation and improved from even the 3V IMO.
#soapbox
Old 08-03-2015, 12:15 PM   #33
#soapbox
You speak the truth bro. The 3.7 is just an improved, updated, better than 2010 and under 4.6 engine that has two less cylinders.
Old 08-03-2015, 03:09 PM   #34
infamous281's Avatar
I'd just enjoy the GT and pay it off , once you get a little older sell it and buy a 03-04 Cobra.
Sent from my SM-N910T using Mustang Evolution mobile app
Old 08-03-2015, 03:13 PM   #35
^ Better yet keep the GT for a daily and have the terminator for nice days.
Pick your poison.
Gaining horsepower through bolt ons thevanman Pre-2005 V6 Mustang 17 10-05-2014 06:04 PM
Gaining power through bolt ons plus some thevanman 2005-2010 V6 Mustang 13 09-29-2014 11:01 PM
It takes power to make power sporter 2005-2010 Mustang GT 3 05-13-2007 07:40 PM
need some help from the electrically inclined (need to find a power transformer) fast64 The Bar 5 05-26-2006 04:58 PM
Working on a high power system but need insight....HELP A MAN OUT PLEASE?!!!! BlueThunder Mustang Audio & Video 1 10-15-2004 11:36 PM
11:28 PM
