Steering problem - Mustang Evolution
Old 07-27-2015, 08:47 PM   #1
Lorenzod02gt's Avatar
Steering problem
Just started noticing that at idle or slow speeds when turning the steering wheel it gets a little tight and then clears up, at the same time my brake pedal sinks. I'm wondering Would this be P/S Pump or Rack?
Lorenzod02gt is offline   Reply With Quote
Old 07-27-2015, 09:20 PM   #2
I would lean towards the pump being the cause of the problem, since both the brakes and the steering are affected simultaneously.
Old 07-27-2015, 09:25 PM   #3
Good point, thanks!
Old 07-28-2015, 09:25 AM   #4
Semerollin's Avatar
Check your fluid.
Semerollin is offline   Reply With Quote
Where can I find steering damper for 66 manual steering? Daniod9 Classic Mustangs 11 11-06-2013 10:19 AM
Steering wheel shaking, power steering? toro 2011-2014 V6 Mustang 3 05-04-2013 06:31 PM
Can you interchange a 1965 mustang steering wheel with a 1967 steering wheel? gruffudd91 Classic Mustangs 1 08-26-2009 04:38 PM
Steering problem kercolla New Member Introductions & Greetings 2 08-21-2009 04:35 PM
Steering problem need help! fastlane350 Pre-2005 V6 Mustang 1 03-19-2008 06:31 PM
08:52 AM
