Front end noise :( - Mustang Evolution
Old 07-27-2015, 10:25 PM   #1
Front end noise :(
Have a nasty front end noise that started today it feels like the front tires have lumps in them it ,like I'm constantly hitting small bumps in the road and gets worse the higher the speed any ideas ?
Also has a popping sound coming from front end when turning in my driveway or parking spots but only does it sometimes. :/ could be the same problem?
It's driving me nuts any tips are appreciated :/
Skax is offline   Reply With Quote
Old 07-28-2015, 01:04 AM   #2
Steve96's Avatar
Ball joint issue possibly?
1996 GT
Old 07-28-2015, 02:01 AM   #3
Brandonj02's Avatar
I had the popping noise there for a little while. Replaced the ball joints and it went away. Is it kinda more like a creaking sound ?
Brandonj02 is offline   Reply With Quote
Old 07-28-2015, 04:54 AM   #4
jeno's Avatar
Control arm bushings
Sent from my Nexus 6 using Tapatalk
jeno is offline   Reply With Quote
Old 07-28-2015, 05:30 AM   #5
Sounds like balljoints here too. Replace with Steeda X2 units.
Old 07-28-2015, 06:03 AM   #6
Yeah I looked under the car and ball joints don't look in good shape ganna try that out and see and I so watched a couple of videos and it only pops one time when they then mine is a continuous Pop when turning still same issue right ?
Old 07-28-2015, 07:10 AM   #7
It's not a creaking sound more like a knocking popping noise
Old 07-28-2015, 04:48 PM   #8
smsstang's Avatar
Mine also does the same when at low speeds like parking or just in the driveway it makes a creaking noise ? With little pops Mabey I should get some new ball joints
smsstang is offline   Reply With Quote
Old 07-28-2015, 04:59 PM   #9
Steve96's Avatar
Yeah sounds like ball joints. Go steeda x2 or get a quality Moog part.
1996 GT
Old 07-28-2015, 09:44 PM   #10
smsstang's Avatar
Would you have to get a bump steer kit if to say that the steeda x2 were to be installed ?
Old 07-28-2015, 09:46 PM   #11
smsstang's Avatar
Old 07-29-2015, 12:27 AM   #12
Brandonj02's Avatar
I have the Steeda ball joints on mine and I didn't do the bump steer kit.
No problems
And side note, you get about a half inch of low if you leave the retainers off on the x2's
Old 07-29-2015, 01:43 AM   #13
Steve96's Avatar
Yeah, no bumpsteer kit required that is used when lowering the whole care and not really needed unless you go more than 2" lower IMO. You could take this opportunity to throw some lowering springs on i recommend HR Supersports, new steeda x2 ball joints, koni STR.T struts/shocks or Tokico HPs, MM CC plates, new poly isos, leave the retainers off the x2s and be close to 2" lower. I know thats a lot but the new edges look so damn good lowered that its almost a must.
---------- Post added at 02:43 AM ---------- Previous post was at 02:42 AM ----------
Yeah, no bumpsteer kit required that is used when lowering the whole car and not really needed unless you go more than 2" lower IMO. You could take this opportunity to throw some lowering springs on i recommend HR Supersports, new steeda x2 ball joints, koni STR.T struts/shocks or Tokico HPs, MM CC plates, new poly isos, leave the retainers off the x2s and be close to 2" lower. I know thats a lot but the new edges look so damn good lowered that its almost a must.
1996 GT
14 front end to 12 front end Cise 2011-2014 V6 Mustang 24 05-17-2015 02:14 PM
For Trade: My 2014 V6 Front End for your 2011-2012 GT Front End CodyC Mustang Parts for Sale and Wanted 3 03-15-2015 08:42 PM
86 front end into an 89 front end Beatjunkiexorge 2.3 Mustang 1 05-18-2013 07:07 PM
Front end Noise ?????? ArmyStangGT 1996-2004 Mustang GT 7 02-09-2009 08:13 AM
05 GT front end knocking noise texastosh 2005-2010 Mustang GT 2 09-01-2007 01:57 PM
04:26 PM
