Nitrous wiring - Mustang Evolution
Old 07-28-2015, 03:01 PM   #1
33wings's Avatar
Nitrous wiring
So I wire up the nitrous and everything is working fine. But when I put the purge in, I wired it up, it had two wires coming from the solenoid, I'm assuming power and ground correct? So I hooked the ground up to ground, the power to a switch, then the wire coming off the switch to the battery. The only thing that happens is the wires heat up really hot and start melting. I'm using 14 gauge wire
33wings is offline   Reply With Quote
Old 07-28-2015, 03:15 PM   #2
keeney35's Avatar
Sounds like something is hooked up backwards, go back over all of your wires and check them
keeney35 is offline   Reply With Quote
Old 07-28-2015, 03:20 PM   #3
33wings's Avatar
As in back words like power to ground and ground to power?
Old 07-28-2015, 04:45 PM   #4
keeney35's Avatar
Yeah pretty much but check throughout the whole wiring set up, make sure the wires are hooked up to we're there supposed to, it's easy to miss something
nitrous
NITROUS. Is my wiring wrong. PLEASE HELP Jsmorley81 2011-2014 Mustang GT 12 02-17-2017 07:36 AM
Nitrous wiring help..... PLEASE Jsmorley81 2011-2014 Mustang GT 3 06-06-2014 08:55 PM
Running a bigger shot of nitrous / NITROUS GUYS Jsmorley81 2011-2014 Mustang GT 5 02-14-2014 01:31 PM
2000 Mustang V6 Wiring Door panel wiring problem wyatt-00' Pre-2005 V6 Mustang 3 11-30-2009 12:43 AM
Nitrous Express wet nitrous kit Zim Mustang Parts for Sale and Wanted 24 06-15-2005 12:43 PM
08:00 AM
