A/C Does not blow cold air - Mustang Evolution
Old 07-31-2015, 08:22 AM   #1
All right, so one day out of the blue my ice cold A/C sh*t itself and now it only blows hot air all of the time.
The clutch does not cut on when I turn the A/C on and when I jumped the low pressure switch it still does not engage.
With one of those Walmart r134 cans with gauge I checked the low pressure port and the pressure read 100 psi. Which is normal for when the A/C is off, or so I read. And it still read 100 psi when the car A/C was on, and the low pressure switch was jumped.
I guess it's worth noting that I can turn the clutch by hand.
What could be causing the clutch to not engage at all even with the low pressure switch jumped? I've searched multiple forums trying to find the answer, or atlas the next step, but I haven't really found anything that pertains to my problem. I've come to the conclusion that I hate A/C systems. The SC heat + no A/C = literal hell.
BTW this is on my 2001 Cobra.
Kay Chisel is offline   Reply With Quote
Old 07-31-2015, 02:53 PM   #2
dwbrand's Avatar
When my truck had that happen, the clutch had to be replaced. Luckily it was replaceable without replacing the compressor, you might not be that lucky with your car.
2003 Ford Mustang GT
1995 Ford F150 XLT 4x4
1968 Mercury Cougar
dwbrand is offline   Reply With Quote
Old 07-31-2015, 03:36 PM   #3
I have to ask the obvious question...
Have you checked all of the fuses related to the AC system?
Old 07-31-2015, 08:23 PM   #4
I'm sorry I should have posted that in the original post. I have checked fuse 24 under the hood and fuses 2, 23, and 24 under the drivers side dash. All of which seem to look good.
I was just out there looking earlier and double checked everything I covered in the original post as well as the fuses. And I looked at the climate control switches and all of the wires look clean with no fraying/slicing.
Old 07-31-2015, 08:42 PM   #5
You can check the electrical connector on the compressor and verify that there is "juice" when you activate the AC. If there is power, then, like dwbrand said, your compressor clutch has likely failed.
Old 08-01-2015, 04:26 PM   #6
fomoco4life's Avatar
CCRM
mustang v6 2012 air condition after use the hot air do not blow cold air blackout2012 2011-2014 V6 Mustang 5 12-14-2014 07:17 AM
A/C doesnt blow cold XSlashDashX 1996-2004 Mustang GT 39 06-05-2013 06:18 PM
COLD AIR INTAKE or SHAKER COLD AIR INTAKE zalizar21 2005-2010 V6 Mustang 14 08-19-2012 07:41 AM
94gt factory cold air intake vs aftermkt cold air intake justjake94boss 1979-1995 Mustang GT 1 04-15-2012 11:22 AM
Blow by blow racings 2011 GT DDTCM 2011-2014 Mustang GT 7 11-11-2010 07:59 AM
12:18 AM
