New heads - Mustang Evolution
Old 07-31-2015, 10:17 PM   #1
keeney35's Avatar
New heads
Looking at getting some new heads to throw in when I install my cams.. Any body have any info on these? Will they work okay with my comp 270's? What kind of gains could I see with adding heads and cams?
Trick Flow Mustang Twisted Wedge Cylinder Heads 44cc Combustion Chambers (96-04) 4.6 2V 51900002PR
keeney35 is offline   Reply With Quote
Old 07-31-2015, 11:22 PM   #2
Trick Flow heads need Trick Flow style cams, they will not work with PI style cams.
Those will run around $3300 with a set of cams plus whatever the install is but the TFS heads are easily the beast heads for the 2V.
2000 Mustang GT Steeda #0048
Old 08-01-2015, 06:03 AM   #3
Slater2111's Avatar
New heads
http://www.modularheadshop.com/Cylin...PI/STG2-C.aspx
Slap on this combo with a stage 2.5 cam and you're good.
But if you Termi swap it you can't use 2V heads obviously.
Sent from the mothership.
Slater2111 is offline   Reply With Quote
Old 08-01-2015, 06:34 AM   #4
keeney35's Avatar
What would work with my comp 270's? Other than rebuilding my current heads
Old 08-01-2015, 06:55 AM   #5
Slater2111's Avatar
They would work very nice in those. But the ones I listed come with cams. They do sell ported heads without cams though.
Old 08-01-2015, 10:48 AM   #6
There are 2 head options for 2Vs. Ported PI heads and TFS heads. Ported PI heads are known to support over 700hp with a power adder and over 7K RPM.
TFS heads are for ppl who want/need to go above and beyond this power level. TFS heads have the valves reversed, among other things. This means that for TFS heads you need TFS style cams and vice versa.
MHS does a real nice set of ported heads and they are the place that got linked to in an above post. There are also local porters/shops depending on where you live but MHS is known to do a really nice set for a reasonable price.
Old 08-01-2015, 07:20 PM   #7
keeney35's Avatar
I guess I could just get mine ported at a machine shop but idk hard decisions
Old 08-01-2015, 07:55 PM   #8
Its going to be as cheap and likely easier to have Nick at MHS do them. Plus if your cores are in good rebuildable shape you can get a little $$$ back for them.
Is your bottom end built yet? If you can get that Termi motor/trans that is going to be your best $$$ for the buck honestly. See how much he wants for just the motor if your trans is in good shape. If not, get the T-56 too.
If you do not have a built bottom end, just throw the cams in and go. If you need a rebuild, you can always do what I'm doing and find a cheap Vic motor and drop it right in.
Old 08-01-2015, 08:20 PM   #9
keeney35's Avatar
I'm trying to find someone who will degree them correctly then have it towed to my tuner
Old 08-01-2015, 08:28 PM   #10
There are plenty of How Twos on degreeing them yourself. Or you can get a degree service done on them. You'll have to mail them out to get it done tho. Cushman does it for his, MHS has a degree service too. Email/call them and ask.
Pro comp heads vs gt 40p heads FordRacer_51 1979-1995 Mustang GT 25 10-11-2012 10:26 PM
4.2L heads? not as good as 3.8 split ports heads? lemons95 Pre-2005 V6 Mustang 0 02-20-2012 08:53 PM
E7 heads or Gt40 heads? Qwik Four Six 1979-1995 Mustang GT 18 10-29-2011 10:59 PM
FS: BV Heads, 173's,Cam, and Stock Heads petrey10 Mustang Parts for Sale and Wanted 4 06-27-2006 12:15 AM
For all metal heads come check out this new band sonic04edge The Bar 20 01-20-2005 03:16 PM
08:46 AM
