Ac compressor not Getting power - Mustang Evolution
Old 08-02-2015, 06:00 PM   #1
The other day I hopped in my car leaving work and turned the ac on it wasn't blowing cool air
Things I've tried :
Testing all fuses with test light
Tested and jumped at low pressure switch
Tested high pressure switch
Tested pressure at low pressure
Turning the clutch to see if it was hung
I was looking for the relay and couldn't find one? Any ideas ?
Skax is offline   Reply With Quote
Old 08-02-2015, 06:31 PM   #2
jeno's Avatar
Just asking the obvious did you check if it has freon
Sent from my Nexus 6 using Tapatalk
jeno is offline   Reply With Quote
Old 08-02-2015, 06:36 PM   #3
I tested the low pressure and it was around 80 psi I believe
Old 08-02-2015, 06:41 PM   #4
jeno's Avatar
I believe that's to high to much or not enough freon will cause the ac to be cool
Sent from my Nexus 6 using Mustang Evolution mobile app
Old 08-02-2015, 06:49 PM   #5
Compressor never kicks in as well I tried emptying the freon and refilling it and had no luck
I tested the switch that plugs into the compressor and it's not getting any power
Old 08-02-2015, 06:49 PM   #6
jeno's Avatar
May be the low pressure switch
Old 08-02-2015, 06:54 PM   #7
I've tested the low pressure switch it's getting power even tried jumping it and had no luck
Old 08-02-2015, 07:13 PM   #8
jeno's Avatar
Then I'm not may be your compressor
Old 08-03-2015, 04:56 AM   #9
fenixignition's Avatar
you said you got 80 psi, what gauge did you use? if its the type thats on top of a can of freon from walmart/autoparts store, then get your hands on one more to make sure the scale wasnt off. ive seen that happen plenty of times (reading way too high or way too low).
the 80 psi he saw was likeley with the compressor off 100 is usually where you wanna be when it is off. you can borrow a reliable set of gauges at Autozone specifically, usually they wont make you pay the loaner cost if you are just using them in the parking lot. depends on the store.
but generally, with the a/c cans with the gauges on top, you should be just in the red zone when the vehicle is off. when it starts running the compressor, it will drop down the green area. Be careful not to add too much freon though. 80 sounds like enough to start the compressor, but i would expect it to cycle on and off.
2002 GT 5sp. 16x,xxx miles
Old 08-03-2015, 10:58 AM   #10
check relay,if you have power to low-pressure switch and no futher most likely relay bad. switch with one for cooling fan..does the rad fan come on when switching on a/c? check pcm for code could be circuit that delays a/c when starting,seen it before on ford, its controlled by pcm
ALLYDRIVER1 is offline   Reply With Quote
Old 08-09-2015, 06:12 AM   #11
You need real ac gages to get a real reading what comes with the can of freon don't cut it
Sent from my SAMSUNG-SM-G870A using Tapatalk
richardlab is offline   Reply With Quote
Old 08-09-2015, 06:15 AM   #12
True^ more or less good for a relativity reading. Otherwise I've seen plenty of those gauges be way off mark.
Sent from my SM-G920V using Mustang Evolution mobile app
Old 08-09-2015, 06:17 AM   #13
Yes filled the wife's ac and it wouldn't blow cold had a friend put his gages on and it was way of
Old 08-09-2015, 11:18 AM   #14
Region: Utah
If your pressure matches the pressure/temp chart here then you have the correct refrigerant charge. 80 psig would be inline if your ambient temp was about 76 (doubtful in the summer considering under hood heat from the sun or engine heat if you had been running it before seeing the 80)
Pressure - Temperature Chart for HFC-134a
'99 GT Vert - K&N CAI, Magnaflow Exhaust, 410 Rear, SCT Tune
Wasatch99GT is offline   Reply With Quote
Old 08-12-2015, 10:36 PM   #15
i used 2 sets of gauges both really good sets, ac pressure lines up right with the chart :/ any other ideas?
Old 08-13-2015, 05:35 AM   #16
I didn't see if this was answered, but does the ac clutch engage? If you have a loose vacuum line, maybe you are running your a/c but the cold air isn't being routed inside the car?
Old 08-13-2015, 12:22 PM   #17
No clutch does not engage :/ I used 2 different sets of gauges as well presdure is fine
Old 08-13-2015, 12:49 PM   #18
Might be time to roll down the windows and let nature be the AC.
Old 08-13-2015, 01:25 PM   #19
That's what it seems like first the compressor locked up a month later clutch won't even kick on maybe it's a sign but I can't deal with this hot *** sun
Old 08-13-2015, 02:40 PM   #20
jeno's Avatar
Originally Posted by Skax View Post
That's what it seems like first the compressor locked up a month later clutch won't even kick on maybe it's a sign 😂😂 but I can't deal with this hot *** sun 😂
Did you buy this compressor or its the one that came with the car if its new then just warranty it out from where you bought it.
Old 08-13-2015, 02:42 PM   #21
Do a pin out on pcm,think you will find problem there
Old 08-13-2015, 02:57 PM   #22
The compressor is literally 2 months old i don't believe it's a compressor problem
Old 08-13-2015, 02:58 PM   #23
jeno's Avatar
A few posts back you said it locked up that was the old one
Old 08-13-2015, 03:11 PM   #24
Yeah the oLd one locked up and broke the belt I replaced the compressor orfice tube dryer belt and flushed the system
Old 08-13-2015, 03:36 PM   #25
jeno's Avatar
Well try what they said and pin the pcm
Mach 460 amps not getting power! VIDEO calebnaasko 1996-2004 Mustang GT 1 07-27-2013 01:50 PM
no power to a/c compressor . 91fun 1979-1995 Mustang GT 6 07-05-2012 01:11 PM
Not getting max power Cleancobra22 General Mustang Discussion 7 06-19-2012 08:38 PM
Not getting power.. HELP Codysmustang 1996-2004 Mustang GT 6 06-24-2011 08:12 AM
1976 ford mustang will not start, not headlights come on, it is not the battery, why? eifion Classic Mustangs 6 08-24-2009 03:12 AM
07:36 PM
