2 inch drop too much? - Mustang Evolution
Old 08-05-2015, 06:06 PM   #1
Going to buy some eibach lowering springs from a guy on craigs list for 75 bucks. Poor s.o.b. never got to put em in his stang before he totaled it. He says they will drop it 2 inches all the way around. I probably won't get them installed until spring so that way I can get the cc plates too over the winter.
Vinnie02 is offline   Reply With Quote
Old 08-05-2015, 06:11 PM   #2
Mile high JDF's Avatar
I think a two inch drop looks great. I had mine slightly lower than that and loved the look.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 08-05-2015, 06:18 PM   #3
Visually the drop is amazing..probably the best drop height for our cars. Depending on where you live 2" lower could make driving a pita. Do consider that.
Also +1 on getting plates. You could probably get away with camber bolts but a good set of plates is the best option. May also want to replace/upgrade shocks/struts/ball joints while you're in there and save time and/or labor.
Old 08-05-2015, 06:59 PM   #4
I like a mild drop all the way around myself. You do need enough suspension travel and also don't want to be scraping every damn where you go. Not to mention not slamming your car allows you to stuff some pretty big tires up front.
Old 08-05-2015, 07:04 PM   #5
Yeah thats why I am probably going to wait until spring to get them in.. I plan on getting shocks, struts,cc plates,and lower control arms over yhe winter. Thanks guys.
Old 08-06-2015, 11:27 AM   #6
i would go with an adjustable shock and strut if going over a 1.5'' drop and don't forget to check out those isolators while your in there.they may need replacing.
newedge01 is offline   Reply With Quote
Old 08-06-2015, 05:11 PM   #7
Searched the parts numbers and they are a 1.5 to 1.75 inch drop which makes me feel better about them.
Old 08-06-2015, 06:04 PM   #8
LaserRed99's Avatar
I think a 1.5" drop is just about right on a 94-04. More than 2" is a little much IMO.
'03 Mach 1 5spd
Fully forged Manley rods/pistons, Cobra crank, ARP hardware, 8.5:1, Procharger P1SC w/ intercooler, AFM power pipe, 60# injectors, 03/04 Cobra tank with dual fuel pumps, Kenne Bell Boost-a-Pump, O/R X pipe and Flowmasters, Exedy stage 3 clutch, Steeda Tri-Ax, Front and rear upper + lower control arms, Ford Racing springs, Bob Monks tune 448 rwhp @ 9 PSI
LaserRed99 is offline   Reply With Quote
Old 08-06-2015, 06:36 PM   #9
I agree laser...can't wait to get them put in in spring time.
Old 08-06-2015, 08:04 PM   #10
dwbrand's Avatar
Spring time... As in, the season? Or when you lower your car?
I crack myself up!
2003 Ford Mustang GT
1995 Ford F150 XLT 4x4
1968 Mercury Cougar
dwbrand is offline   Reply With Quote
Old 08-06-2015, 08:27 PM   #11
Lol dw... season
Swaybays: Is too thick too much? 2 Stangz 2005-2010 Mustang GT 2 04-08-2015 02:44 PM
Drop or no drop OzzyLiriano 2011-2014 Mustang GT 15 12-10-2012 12:04 PM
2 inch drop ? Texasstang 2005-2010 V6 Mustang 32 10-08-2011 07:11 AM
Too much money too much time ridenmystang Pictures and Videos 2 07-27-2006 02:50 PM
2" drop too much? tedness Pre-2005 V6 Mustang 8 03-31-2005 07:31 PM
03:22 PM
