Worried - Mustang Evolution
Old 08-06-2015, 01:09 PM   #1
BeastyStang's Avatar
Worried
So over the last weekend, I decided to remove the intake manifold, and left the car alone. Today, that i have the day off, i decided to really clean the engine. I came across this....Click image for larger version
Name:	ImageUploadedByMustang Evolution1438888137.118155.jpg
You can't tell in the pic, but there's coolant in there. I checked the rest of the holes, they are all free of fluid. Is this normal?
BeastyStang is offline   Reply With Quote
Old 08-06-2015, 05:03 PM   #2
Mile high JDF's Avatar
Depending on which port that is, that could be a coolant passage.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 08-06-2015, 07:14 PM   #3
It's the closest one to the passenger side.
Old 08-06-2015, 08:12 PM   #4
Is that port right next to one of the coolant passages in the head?
If so, it is possible that it got there when you removed the intake manifold.
Antifreeze/Coolant takes longer to evaporate than straight water, so it can stay in there for quite a while.
Old 08-07-2015, 01:30 AM   #5
What would I need to do to get the coolant from out there?
Old 08-07-2015, 02:02 AM   #6
maldog's Avatar
Region: Nevada
Use a small vacuum and suck it outta there.
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 08-07-2015, 05:44 AM   #7
Small vac and out it goes. Or get a can of compressed air and blow it all out. Any residual will get burned off in a few seconds once you start up.
Old 08-07-2015, 10:11 AM   #8
fenixignition's Avatar
a few paper towels to absorb it might even work. roll it up nice and thick, and jam it in there.
2002 GT 5sp. 16x,xxx miles
Old 08-07-2015, 10:22 AM   #9
I will definitely try all. Thanks gentleman. I appreciate the help!
Worried about car report on mach 1?help? MachMan1017 General Mustang Discussion 29 08-23-2012 11:18 AM
Inspection time... Little worried Silversky545 2005-2010 Mustang GT 57 05-09-2012 11:19 AM
Should I be worried about mustang year? MadGatter General Mustang Discussion 25 01-31-2011 11:37 PM
should i be worried?? powerhungry966 Pre-2005 V6 Mustang 1 05-24-2006 12:39 PM
I'm worried.. Seph Regional Mustang Discussion 4 09-30-2005 01:09 PM
02:09 AM
