Upper plenum gasket - Mustang Evolution
Old 08-07-2015, 08:53 AM   #1
dwbrand's Avatar
Upper plenum gasket
I'm trying to get my ducks in a row before installing the used Accufab throttle body/plenum that I picked up.
Is there a gasket between the upper plenum and the intake manifold? Parts websites show an o-ring type gasket but I've noticed no plenums or TB/plenum combos come with this gasket. So if its there, is it replaceable and do I need to?
2003 Ford Mustang GT
1995 Ford F150 XLT 4x4
1968 Mercury Cougar
dwbrand is offline   Reply With Quote
Old 08-07-2015, 10:09 AM   #2
fenixignition's Avatar
it usually comes with an intake manifold. go to an autoparts store and grab a fel pro plenum gasket.
2002 GT 5sp. 16x,xxx miles
Old 08-07-2015, 10:12 AM   #3
dwbrand's Avatar
Thanks! I'll be sure to do that
1968 Mercury Cougar
Old 08-07-2015, 10:37 AM   #4
Its a little light blue or orange rubber gasket. There is a groove in the intake it sits right into. If you already have the rubber one there then you are good. They are re-usable unless they are trashed.
Old 08-07-2015, 11:17 AM   #5
dwbrand's Avatar
Thanks Scotty, I wondered about that. The local stores don't stock it so I'm going to try to pick one up this weekend just to have in case I need it.
1968 Mercury Cougar
Old 08-07-2015, 01:05 PM   #6
Rockauto sells it. Hell Amazon probably does too. I've found that with a Prime membership you can often cross reference Rockauto part numbers on Amazon and save an assload of money on shipping and get it in 2 days too.
Old 08-07-2015, 01:17 PM   #7
dwbrand's Avatar
Haha I just let my Prime membership expire. It's not worth $100 to me. Last year I let it go too and not long after they sent me an offer to get it for $50. I'm waiting to see if they do that again.
I'm headed south this weekend and I've called CarQuest down there. They will have it in the morning and since I used to work there, they still give me employee cost 👍🏻
1968 Mercury Cougar
intake plenum gasket UDBigJim 1996-2004 Mustang GT 1 09-11-2013 05:34 AM
upper plenum gasket truckinu General Mustang Discussion 3 02-27-2013 06:52 PM
Upper intake plenum gasket and EGR gasket McNassty General Mustang Discussion 1 06-08-2012 10:51 AM
Is a valve gasket the same as a valve cover gasket? birtingr General Mustang Discussion 6 03-15-2010 02:24 AM
Pro Ported upper intake plenum on my 4.6L 99+.... Rick0636 The Bar 8 01-15-2004 07:43 AM
11:35 AM
