Driver power window stopped working - Mustang Evolution
Old 08-07-2015, 10:50 AM   #1
I have a 2003 Cobra SVT convertible. Yesterday the driver's window stopped working. All of the other windows work. When I depress the rocker switch, I hear a clicking sound and the interior lights slightly dim. Based on this, I believe the switch is OK and power is getting to the relay. Need advice. Thanks!
etihw is offline   Reply With Quote
Old 08-07-2015, 01:27 PM   #2
Switch is good. My guess is the regulator. Which you can do yourself but prepare your 4 letter vocabulary.
Old 08-07-2015, 01:36 PM   #3
It sounds like the motor is working.
I haven't had the opportunity to remove one of these window motors, but older Ford motors have three little nylon bushings that act as shock absorbers for the motor. When they wear out, the motor will make a clicking sound. It sounds like a gear is stripped.
On the older motors, you can buy a rebuld kit. The only thing that you really need to replace are the bushings though.
You have to remove the motor to rebuild it, just the same as if you were replacing the whole thing.
Old 08-07-2015, 07:48 PM   #4
Thanks!
I will check it out!
Old 08-09-2015, 09:52 PM   #5
mineralgt's Avatar
Hold the window switch the direction you want it to go and bang the door panel with your fist near the speaker. If it starts working its definitely the motor
mineralgt is offline   Reply With Quote
Old 08-10-2015, 12:08 PM   #6
I've had my 2002 gt vert for just over a year. Same thing happens. But it is only when it is above 85 and humid. It just needs a little love tap behind the speaker like he said. Hold the switch down when you do it.
Alewan_02_GT is offline   Reply With Quote
radio randomly stopped working it seems to be wireing any help The420fox 1979-1995 Mustang GT 8 06-04-2013 12:27 PM
My Color stopped working! AndreaCristiano 2011-2014 V6 Mustang 10 01-12-2013 07:09 PM
Radio stopped working twotone01 Pre-2005 V6 Mustang 3 05-11-2012 04:08 PM
speedo stopped working lilrafe87 1979-1995 Mustang GT 7 04-03-2012 11:59 AM
gas gauge stopped working! please help! ugafan_1207 1979-1995 Mustang GT 18 01-14-2011 12:18 AM
02:40 PM
