NEED HELP !! - Mustang Evolution
Old 08-09-2015, 12:44 PM   #1
NEED HELP !!
I working on axles , differential and gears swap . I put everything in but im stuck at the gears with the teeth patterns .. the teeth patterns are dead centered. But the differential is moving side to side . Is it normal? Or should it be firm ??
jking97gt is offline   Reply With Quote
Old 08-09-2015, 01:18 PM   #2
Mile high JDF's Avatar
Are you sure it's not just the differential backlash? There should be between eight and fifteen thousandths of play between the ring gear and the pinion gear. If you have horizontal play then your bearings are probably trashed.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 08-09-2015, 02:50 PM   #3
You need to put the rear end back together just like it was taken apart. The installation is the reverse of the removal. And you need to reinstall all of the parts including the C-clips.
Here's a how-to guide. http://diyford.com/ford-8-8-inch-axl...ide-step-step/
Sent from my SAMSUNG-SGH-I747 using Mustang Evolution mobile app
Old 08-10-2015, 10:27 PM   #4
Panther140's Avatar
There is play in the side gears in the differential, if thats what you're talking about. It shouldn't be a lot, but the gears actually move outward when there is a lot of force in the differential. This outward movement is caused by the gears natural thrust force, and is what presses the gears against the clutches to lock the differential. Under light load or turning, the gears do not get forced outward to press against the clutches, which is allows the wheels to spin at slightly different speeds around the circumfrance of a turn
I am not sure how much play you are seeing, or where it is exactly. But that is one thing to keep in mind.
---------- Post added at 11:27 PM ---------- Previous post was at 11:27 PM ----------
Panther140 is offline   Reply With Quote
Need 12v under hook, need help with headlight wiring dseg 2011-2014 Mustang GT 0 06-17-2015 08:49 PM
Need quick help! Need to find 4.10 gears for 2010 v6 mustang?? Camaro Eater Pre-2005 V6 Mustang 2 06-08-2010 05:31 AM
Guys need help.. going to get new engine.. need advice Skyes97Stang Pre-2005 V6 Mustang 9 11-28-2009 12:35 AM
need some help from the electrically inclined (need to find a power transformer) fast64 The Bar 5 05-26-2006 03:58 PM
Need to choose new tires..need help KyleUSAF Mustang Wheels & Tires 13 11-29-2005 11:13 AM
12:09 AM
