Drive shaft - Mustang Evolution
Old 08-09-2015, 02:13 PM   #1
001Gt's Avatar
Drive shaft
Name:	ImageUploadedByMustang Evolution1439151192.338107.jpg
Thoughts on this
2001GT slow_2V
001Gt is offline   Reply With Quote
Old 08-09-2015, 02:19 PM   #2
Well, that depends on what your goals and expectations are............is there something wrong with your current driveshaft?
I would expect, that with a significantly lighter driveshaft, you would notice a difference in the "flywheel effect" as to how the engine drives.
It does look like the driveshaft for your year costs about 1/2 of what the newer ones cost....so why not go ahead, right?
Old 08-09-2015, 02:36 PM   #3
My first thought is "Wow! Aluminum driveshafts have gotten expensive!"
Old 08-09-2015, 05:40 PM   #4
I paid $165 shipped for my FRPP shaft in 2002... Ugh, yeah its doubled. Its something that should be one of the last things you do.
Just make sure you you do get one you get the 31 spline unit. Would not be the first person who got the tailshaft and rearend spline count confused. T45s and 3650s have 31 spline outputs which is one less thing to upgrade when/if you get one built.
Old 08-09-2015, 05:50 PM   #5
001Gt's Avatar
I'm starting to feel a lot of vibration
2001GT slow_2V
Old 08-09-2015, 05:52 PM   #6
It may not be the driveshaft. Do the vibes happen if you gun the motor sitting still in neutral? Are the vibes RPM or speed dependent?
Old 08-09-2015, 05:54 PM   #7
001Gt's Avatar
Its starting to vibrate
2001GT slow_2V
Old 08-09-2015, 06:16 PM   #8
NewMtang's Avatar
Anything aluminum has gone up in price. Try pricing a 6ft aluminum ladder.
Old 08-09-2015, 06:39 PM   #9
Or.........a new F-150!
Old 08-09-2015, 08:33 PM   #10
2001GT slow_2V
If you think that the vibration is coming from the drive line, jack the car up and check the four bolts that connect the driveshaft to the rear end. Sometimes they can become loose and cause a vibration. Also check the U-joints for any play.
Old 08-09-2015, 08:45 PM   #11
jeno's Avatar
Also check the transmission mount had bad vibrations in my car mount was shot replaced and all is good now
Sent from my Nexus 6 using Tapatalk
jeno is offline   Reply With Quote
Old 08-09-2015, 09:30 PM   #12
2001GT slow_2V
Like I said... that automatically does not mean driveshaft.
Old 08-09-2015, 09:42 PM   #13
I got a crap load of vibration at 80+ after I installed my torque arm. Did an aluminum driveshaft and it all cleared up. Feels much smoother now.
Old 08-10-2015, 06:24 AM   #14
001Gt's Avatar
Thanks for the help. I think it might be the trans mount because when I take corner I can feel it move a little. But I might still buy the shaft, I've heard you get good gains from it
2001GT slow_2V
Old 08-10-2015, 07:36 AM   #15
jeno's Avatar
2001GT slow_2V
Yup like 40 HP lol same issues looked at everything it ended up being the trans mount
Sent from my Nexus 6 using Mustang Evolution mobile app
Old 08-12-2015, 07:31 AM   #16
001Gt's Avatar
What's the difference between this one and the one piece????
2001GT slow_2V
Old 08-12-2015, 10:58 AM   #17
2 piece shafts didn't start until 2005. Don't worry about it.
Old 08-12-2015, 11:07 AM   #18
natestang07's Avatar
Why the hell did they start?
Old 08-12-2015, 11:12 AM   #19
jeno's Avatar
Ford engineer's thought it was a good idea
Old 08-12-2015, 12:04 PM   #20
No having to worry about pinion angle is nice too. Except its just one more point of failure.
But again, not an issue in 04-down because those were all 1 piece shafts. And I'd say 95% of the bolt on crowd will look at you like you have 3 heads if you ask if they properly set their pinion angle after lowering the car. Although lowering doesn't usually hurt anything and if it does then there are plenty of options.
Old 08-12-2015, 05:50 PM   #21
001Gt's Avatar
Oh I I just thought cause one says one piece and the other one doesn't... But never mind ha I get it now I don't know why I asked 😅
2001GT slow_2V
Old 08-13-2015, 10:09 PM   #22
If you lower the same front and back it should stay the same.
Balancing drive shaft or replacing drive shaft Iryan7 Pre-2005 V6 Mustang 6 03-22-2015 11:57 AM
Rear and or drive shaft noises Mean green 91 1979-1995 Mustang GT 9 04-07-2011 05:41 PM
Aluminum Drive Shaft? Paincake1 Pre-2005 V6 Mustang 5 01-22-2009 05:41 PM
FS: NEW IN BOX Drive shaft loop Loco Mustang Parts for Sale and Wanted 0 11-27-2005 09:05 AM
Got my aluminum Drive shaft and Bullitt pedals WooHoo!!! Danger Dude Pre-2005 V6 Mustang 13 12-09-2003 07:57 AM
06:13 PM
