Air isn't blowing through vents. Defrost only? - Mustang Evolution
Old 08-10-2015, 10:29 PM   #1
thump's Avatar
Been reading different forums and from the title you can see my problem. I have a 03 gt and I assume it's a vacuum leak or ac control module. I'm currently checking for leaks under hood and under dash. I notice this hose separated but dunno if it's correct hose for my problems. I have attached a pic. Should these two red tubes be connected and if not who do they go to. Thanks
Name:	ImageUploadedByMustang Evolution1439267331.256672.jpg
ID:	189088Click image for larger version
Name:	ImageUploadedByMustang Evolution1439267345.108336.jpg
ID:	189089Click image for larger version
Name:	ImageUploadedByMustang Evolution1439267360.399389.jpg
ID:	189090Click image for larger version
Name:	ImageUploadedByMustang Evolution1439267371.838578.jpg
"If you build it, they will come"
thump is offline   Reply With Quote
Old 08-11-2015, 06:50 AM   #2
jeno's Avatar
You need to have those lines connected here's a pic on my engine how its connected
Sent from my Nexus 6 using Mustang Evolution mobile app
jeno is offline   Reply With Quote
Old 08-11-2015, 06:53 AM   #3
jeno's Avatar
Sent from my Nexus 6 using Tapatalk
Old 08-11-2015, 07:00 AM   #4
thump's Avatar
Thanks man I figured out this morning. Can that hose and plug be bought.
Old 08-11-2015, 07:02 AM   #5
jeno's Avatar
Yea just buy new vacuum hose at your local auto parts store
Old 08-11-2015, 07:03 AM   #6
thump's Avatar
Great I'll swing by there after work.
Old 08-11-2015, 07:11 AM   #7
jeno's Avatar
Just have them come out to your car and show them what your looking for so they have a better idea good luck
Old 08-11-2015, 07:15 AM   #8
dwbrand's Avatar
Talk about breaking at the wrong point...
My 95 F150 did the same thing. Took it to a small Ford dealer who tried telling us the motor had no vacuum and with 25,000 miles needed replaced. I nosed around and found like three broken/decayed vacuum lines. Truck now has 196k on a "junk" motor.
2003 Ford Mustang GT
1995 Ford F150 XLT 4x4
1968 Mercury Cougar
dwbrand is offline   Reply With Quote
Old 08-11-2015, 07:24 AM   #9
thump's Avatar
Old 08-11-2015, 07:27 AM   #10
thump's Avatar
Yea they were definitely trying to get over on the inexperienced
Old 08-12-2015, 05:31 AM   #11
Just buy a tube and slip both ends into the tube and there you go. Any vac leak like that can jack up the HVAC controller. Happened to my Expy right after I first got it. Vac line disconnected by the firewall, plugged it back in and have not had a problem since.
Old 08-12-2015, 04:49 PM   #12
thump's Avatar
Where is the Blend door actuator located?
Old 08-12-2015, 04:55 PM   #13
thump's Avatar
Freon installed to the proper amount. Ac now comes on and stay on and is engaged but no cool air blows only hot.
Ac blows threw floor and defrost only 95convertible Pre-2005 V6 Mustang 8 09-20-2014 03:16 AM
The fan in my car only is blowing threw defrost? Help 1995boss 1979-1995 Mustang GT 2 08-08-2012 04:54 PM
Blow Through vs. Draw Through, HELP!! CodyNelson 1996-2004 Mustang GT 7 01-06-2012 04:26 PM
Chevy isn't the only transformer USAF_stang Pictures and Videos 10 07-25-2011 05:01 PM
MY AC IN MY 1997 MUSTANG ONLY BLOWS THROUGH THE TOP AND BOTTOM VENTS WHATS WRONG...? hobbard 1996-2004 Mustang GT 1 08-24-2009 12:12 PM
11:53 AM
