Tumbling 'feeling' - Mustang Evolution
Old 08-11-2015, 04:08 PM   #1
robin_gt's Avatar
Tumbling 'feeling'
Alright people so since a couple weeks i've been noticing a tumbling feeling (kinda like sheets in the washing machine) that increases with speed and i'm pretty sure that it's coming from the front end. I replaced ball joint about 7k miles ago and just did swaybar link ends today. The weird thing is that you cant really hear it, i just feel it. Its the worst at low speeds and when i get up to higher speeds i don't feel it.
Thanks
Any suggestions?
robin_gt is offline   Reply With Quote
Old 08-11-2015, 04:33 PM   #2
jeno's Avatar
Check your wheel balance?
Sent from my Nexus 6 using Tapatalk
jeno is offline   Reply With Quote
Old 08-11-2015, 04:36 PM   #3
robin_gt's Avatar
I had the wheels balanced by AM when i bought them and all the weights are still there. One thing i did notice was tho that there is way less thread on the right wheel than on the left wheel.
Old 08-11-2015, 04:39 PM   #4
jeno's Avatar
How long ago did you buy them rule of thumb you should be balancing your wheels every 5000 miles or so. With that lower tread on the right wheel sounds like you have a suspension problem or a bad alignment
Old 08-11-2015, 07:28 PM   #5
You did get an alignment right?
Old 08-11-2015, 07:45 PM   #6
robin_gt's Avatar
Yes but i installed a couple things like bumpsteer kit, dropped the k for longtube install and all that good stuff maybe an alignment would be appropriate lol
Old 08-11-2015, 07:47 PM   #7
robin_gt's Avatar
Can a wheel bearing cause that kind of tumbling because one day i was driving in the rain and when i parked i noticed that my front right center cap was missing, the dust cap somehow got loose and knocked it out. Water definitely got under the dust cap and im assuming it messed up the wheel bearing. Should i stay away from auto part store brand wheel bearings?
Old 08-11-2015, 07:59 PM   #8
You need to replace the entire wheel hub/bearing assembly. I bought a pair of Motorcraft hubs from Rockauto.
I understand that the bumpsteer kits are kind of tricky to install correctly. That would be the first thing that I would check, relating to the uneven tire wear problem.
Old 08-12-2015, 06:41 AM   #9
keeney35's Avatar
I'd deff get it aligned I dropped my k for my longtibe install and noticed the same thing, had to replace the inner and outer tie rods as well
keeney35 is offline   Reply With Quote
Old 08-12-2015, 06:44 AM   #10
Get an alignment and replace both hubs. Hubs are easy. Probably are going to need new front tires too if one is boogered up.
Tumbling noise please help robin_gt 1996-2004 Mustang GT 5 02-25-2015 06:11 PM
Clutch Feeling Sponge-like 19Delta Pre-2005 V6 Mustang 10 04-14-2009 02:07 PM
Feeling it... MarkuzLS1 The Bar 10 10-15-2007 10:30 AM
Are you feeling depressed and feel like you have no life? Seph The Bar 30 11-01-2006 01:21 PM
V8 feeling strike1980 Pre-2005 V6 Mustang 10 05-19-2006 07:22 PM
07:59 PM
