Overheating - Mustang Evolution
Old 08-12-2015, 06:29 PM   #1
richie895's Avatar
Overheating
Need all the help I can get please and thanks! So my car randomly started over heating, I changed my upper radiator hose and the radiator cap, I see no clear signs of leakage anywhere. It doesn't matter if it's stop and go traffic or highway cruising, the needle just continues to rise. My fan works (not sure if it's working good enough). I noticed it lost coolant somehow over night but there was no leak or coolant on the ground and when I refilled it, it's like it didn't even happen, drove on it for a few days and it kept all the coolant I left in it. Only thing I've yet to check is my water pump but I haven't gotten the time to get on that yet and I hear the thermostat is rarely ever goes out but my car does have 215k miles so that may or may not be the problem as well, any solutions as to why it's over heating constantly? Questions and answers welcomed
Hear me before you see me
richie895 is offline   Reply With Quote
Old 08-13-2015, 01:32 AM   #2
Steve96's Avatar
Could you be losing the coolant to a bad intake gasket? Or bad intake? These are notorious for intake issues. Leaking into the block and thats why you arent seeing any drips?
1996 GT
Old 08-13-2015, 05:41 AM   #3
fenixignition's Avatar
Sounds like it could be a stuck thermostat. Maybe when changing the radiator hose, you lost some coolant, but didn't see it until it warmed up. Added coolant and it was back to normal. Not sure how you would have lost much coolant changing the upper hose. But then again, the new radiator cap now allowed you to pressurize the system, so the level in the tank would then drop. I'd grab a thermostat to be safe. It's right underneath the round metal piece that your upper hose connects to. Grab a gasket too. (O ring)
Sent from my SM-G920V using Mustang Evolution mobile app
2002 GT 5sp. 16x,xxx miles
Old 08-13-2015, 07:23 AM   #4
Project Pony's Avatar
Have the radiator checked for flow. You could have some blockage in there. Especially over the 200k mark. They are inexpensive and super easy to replace. Also check the weep hole on the water pump. Personally if it were my car I would replace the hoses, t stat, radiator, and water pump. May not all be necessary, but on a high mileage car, the piece of mind is worth it. And I'm never against preventative maintenance.
[SIGPIC][/SIGPIC]
Old 08-13-2015, 07:14 PM   #5
richie895's Avatar
Overheating
Update.....it was the thermostat 😑😑😑😑, it was stuck open so it wasn't regulating the heat properly, which also was throwing off my ac compressor and it wouldn't kick on when it was supposed to. Thanks for all the help tho guys
Old 08-13-2015, 07:17 PM   #6
Rapinator126's Avatar
---------- Post added at 07:17 PM ---------- Previous post was at 07:17 PM ----------
Originally Posted by richie895 View Post
Update.....it was the thermometer 😑😑😑😑, it was stuck open so it wasn't regulating the heat properly, which also was throwing off my ac compressor and it wouldn't kick on when it was supposed to. Thanks for all the help tho guys
*Thermostat
Old 08-13-2015, 07:20 PM   #7
richie895's Avatar
*Thermostat
Lmfao my b I'm still woozy from replacing it while the car was still hot 😂🙊
car overheating AGAIN!!!! Senorjizzy Pre-2005 V6 Mustang 4 09-01-2009 08:04 AM
Overheating 06 probchld1953 2005-2010 Mustang GT 7 06-10-2008 07:25 AM
Overheating problem? Fast93Coupe 1979-1995 Mustang GT 1 07-01-2006 12:29 PM
Overheating problem NorwegianMustang Pre-2005 V6 Mustang 7 04-27-2005 02:52 PM
yet, another overheating story. juanmiguel Pre-2005 V6 Mustang 15 01-04-2005 12:10 PM
06:01 AM
