Please help! Ac runs but hot air only Freon level checked - Mustang Evolution
Old 08-13-2015, 06:39 AM   #1
thump's Avatar
Compressor kicks on when I cut it on and stays running. The lines get cold. Accumulator gets cold. I have the air finally blowing through vent (it was stuck on defrost mode at first from broken vacuum line). Air switches from floor to defrost to vents mode properly. High and low speed works properly. Freon levels check properly but when I switch the temperature knob from hit side to cold side it stays hot either way. Do you think it's a temperature blend door actuator stuck on warm or something.
"If you build it, they will come"
thump is offline   Reply With Quote
Old 08-13-2015, 07:11 AM   #2
Project Pony's Avatar
I think your on the right track. Sounds like a blend door issue.
[SIGPIC][/SIGPIC]
Old 08-13-2015, 07:28 AM   #3
jeno's Avatar
Yeah second the blend door that's what happened on my foxbody
Sent from my Nexus 6 using Tapatalk
jeno is offline   Reply With Quote
Old 08-13-2015, 07:45 AM   #4
If it's anything like fixing the one in our old 98 5.0 EB Explorer, it will be a pain in the ***, but not expensive if you do it yourself.
Sent from my SAMSUNG-SM-G920AZ using Mustang Evolution mobile app
[SIGPIC][/SIGPIC]
Old 08-13-2015, 08:05 AM   #5
thump's Avatar
Where is it actually located. Do you also think it could be a defective control unit and possibly that needs replacing I see them on eBay for $15-40 bucks
Old 08-13-2015, 09:08 AM   #6
It could be, but I'd get in there and make sure there isn't any mechanical damage before throwing parts at it. They are usually in the dash near the center.
[SIGPIC][/SIGPIC]
Old 08-13-2015, 09:20 AM   #7
jeno's Avatar
Little bit of a pain in the *** but definitely doable
Old 08-13-2015, 09:53 AM   #8
thump's Avatar
Ok I'll give it a look again when I get off. Could you tell me what this piece is. And what it controls Click image for larger version
Name:	ImageUploadedByMustang Evolution1439481220.988301.jpg
Old 08-13-2015, 06:03 PM   #9
That is the actuator for the blend door.
When you turn the temperature control dial of the HVAC control panel, it moves that actuator via a cable. The blend door swings back and forth, and when the control dial is turned all of the way to the "cold" position, the door closes off the section where the heater core is located, thus, blocking the air from being able to pass through the heater core.
Old 08-13-2015, 06:49 PM   #10
thump's Avatar
Thanks I think that is my problem.
NY Help - I need a Mustang checked out before I purchase it. intheclouds1977 Regional Mustang Discussion 0 05-12-2015 03:33 PM
mustang v6 2012 air condition after use the hot air do not blow cold air blackout2012 2011-2014 V6 Mustang 5 12-14-2014 07:17 AM
R134a freon conversion 91MustangNSB 1979-1995 Mustang GT 1 04-24-2013 09:06 PM
99 Cobra Freon V6in SVT Mustang 2 04-21-2013 03:17 PM
Freon Gray Ghost 1979-1995 Mustang GT 4 05-20-2009 11:02 AM
02:50 AM
