My 2002 Mustang GT is making a weird noise - Mustang Evolution
Old 08-13-2015, 07:15 PM   #1
Angry My 2002 Mustang GT is making a weird noise
I'm pretty sure it's an exhaust noise. Its fine when it idles but when I start to rev it or drive it, it makes like a weird popping noise. Repeatedly. I don't know if it's a broken gasket where it connects from behind the cats or a crack in the muffler. It can't be the cats because those ratlle when broken. This is more of a pop. Like i said when it's reving is when it makes the sound. If im driving and let off the gas the sound goes away.
SO, I THOUGHT it was an EXHAUST problem... but I looked into it more and i'm thinking it's an engine problem, like a gasket or something.
Here is a youtube video.
https://youtu.be/1Lj1RUqWe7g
aqsanc is offline   Reply With Quote
Old 08-13-2015, 07:45 PM   #2
jeno's Avatar
Post a video makes it a little easier
Sent from my Nexus 6 using Tapatalk
jeno is offline   Reply With Quote
Old 08-14-2015, 04:30 PM   #3
torchdNblazen03's Avatar
Ny
torchdNblazen03 is offline   Reply With Quote
Old 08-14-2015, 05:16 PM   #4
jeno's Avatar
Hmmm sounds like valves timing chain slap or rod knock if its a rod knock then you engine is on the way out is your oil where its supposed to be others will have input but sounds like a rod knock because it increases with more rpms
Old 08-14-2015, 06:41 PM   #5
HaykoGT's Avatar
I've had a similar noise coming from the exhaust manifold. When i got my clutch replaced the mechanic forgot to tighten the manifold bolts all the way.
But you could have a bad flange gasket
Sent from my SAMSUNG-SM-G925A using Mustang Evolution mobile app
HaykoGT is offline   Reply With Quote
Old 08-14-2015, 06:52 PM   #6
jeno's Avatar
Easiest way to figure this out go to a Muffler shop to see if its an exhaust leak at that will rule that out
Old 08-15-2015, 10:32 AM   #7
yogibooboorange's Avatar
Valve rocker noise maybe. Use a wooden dowel, place it on area where noise is loudest and put your ear to the dowel. Or stethoscope (mechanics). It does not sound like a rod but it is hard to tell. Rattling loose metal shroud rear of engine area/cats. I had a loose metal shroud on another car that popped partially loose and rattled just like that.
yogibooboorange is offline   Reply With Quote
Old 08-15-2015, 12:25 PM   #8
XSlashDashX's Avatar
Same noise as mine. No metal shavings in oil filter during oil change.
Loud during cold start up and it quiets down while its warmed up but still noticeable. I do have LT catted x pipe though. But doesn't sound like exhaust but could be wrong. I figured it was something to do with the timi g chain.
Old 08-16-2015, 10:25 AM   #9
johnathan2225's Avatar
Region: West Virgina
Sounds like mine did, then mine got worse, ended up being a bearing on #8 cylinder
http://youtu.be/phPqVFHtwbA
Sponsored at;
http://www.carsponsors.com/dap/a/?a=86212
5.0l auto, swapped out with 4.6l 5 speed, summit cold air, 17"saleen, cat delete, rear o2 delete, H-pipe, 94 body and rear end, 99 everything else..
johnathan2225 is offline   Reply With Quote
Old 08-19-2015, 03:18 PM   #10
Took it to jiffy lube, they took a look under the car and didn't notice anything out of the ordinary. They also checked fluids and everything was perfect... Can't tell what's wrong exactly. I'm hoping it's just something loose, but can't seem to pinpoint it.
Old 08-19-2015, 03:48 PM   #11
Mile high JDF's Avatar
Don't do this... most of the guys working there can barely turn a wrench let alone diagnose an engine noise
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 08-19-2015, 04:39 PM   #12
Jbone007's Avatar
Have you had the plugs changed recently? I had a noise on my 2000 GT that I thought was a exhaust leak, but it was the #1 plug, it actually blew out of the head!
Jbone007 is offline   Reply With Quote
Old 08-19-2015, 05:20 PM   #13
HaykoGT's Avatar
A blown plug would sound a lot worse
Old 08-19-2015, 06:07 PM   #14
Yeah a lot worse. Know for experience. Sounds nothing like a blown plug.
Old 10-14-2015, 06:24 PM   #15
**UPDATE**
So I noticed that the sound only starts to happen once the car has warmed up a bit. If I drive it cold the noise doesn't happen. It'll take like 4 to 5 minutes for the noise to start. Also, I noticed when I engage and disengage the clutch it makes the sound when the clutch is about halfway in (going all the way down) and again at the halfway mark when I let off the clutch (on the way back up).
Old 10-15-2015, 09:27 AM   #16
fenixignition's Avatar
finally had a chance to listen to the audio. doesnt sound internal to me, but thats mostly guesswork on what it sounds like in person.
2002 GT 5sp. 16x,xxx miles
2002 mustang
2002 mustang gt making noise when turning ? smsstang 1996-2004 Mustang GT 16 06-04-2015 08:03 AM
2007 mustang making a weird sound at startup Drakma675 2005-2010 V6 Mustang 2 09-08-2013 11:39 AM
96 mustang making loud screeching noise from engine.. HELP! Justin96 1996-2004 Mustang GT 1 02-08-2013 05:51 PM
2005 mustang making a squeeling noise when the air is blowing? help!? Tye General Mustang Discussion 3 12-15-2011 07:24 PM
2008 Mustang v6 Auto is making a clicking noise From the middle of the engine ? beverleigh General Mustang Discussion 5 04-01-2010 06:26 PM
11:03 PM
