What's Next?? - Mustang Evolution
Old 08-14-2015, 10:32 PM   #1
What's Next??
I just bought a 2003 GT. the car has the following mods. What would be your suggestion to do next to get some more horsepower?
Vortec v-2 supercharger
Cold air intake
Pro chamber h pipe and mufflers
Kenne bell boost a pump
Other than the above, the car is completely stock. What hp do you believe it's putting out now?
On another note, the car sounds like it has an exhaust leak. Is there a way to nail down where the leak may be coming from exactly or is that work for an exhaust shop?
Quadracer18 is offline   Reply With Quote
Old 08-14-2015, 10:37 PM   #2
If it's supercharged just swap the pulley/belt and increase the boost.
Old 08-14-2015, 10:46 PM   #3
Steve96's Avatar
It all depends on how much boost and tune. I would assume somewhere in the neighborhood of 370-400 or so? I would get it professionaly tuned if it was me so i know where i stood as far as power and also for piece of mind that its not pushing the limits of the stock internals
1996 GT
Old 08-14-2015, 10:55 PM   #4
The previous owner said the car was tuned by a local shop. I'm not sure how well they did. The car also came with a tuner. What's the purpose of that if a shop should tune the car. Is the tuner supposed to be plugged in all the time?
Old 08-14-2015, 10:56 PM   #5
The tuner is only plugged in when uploading the tune to the car. They may have made a more aggressive tune and a more conservative tune. Only way to find out is plug it in and see what options it gives you.
Old 08-14-2015, 11:02 PM   #6
Ok so when a shop tunes the car, they physically need a tuner to "save" the info and put it on the car? I'll have to plug it in and see if there's options...
Old 08-14-2015, 11:07 PM   #7
Generally a shop doesn't need a tuner to save them on. They can upload it straight to the car if they are able to. But a lot of people choose to also save it on a device for themselves.
Old 08-14-2015, 11:09 PM   #8
Thanks for the info! There's no damage I could cause by plugging the tuner in a looking around, correct?
Old 08-14-2015, 11:10 PM   #9
Correct.
Old 08-14-2015, 11:10 PM   #10
retiredvet's Avatar
Yup priority number one is get it to a shop and have them tune it. They dont charge as much if u bring your own tuner usually just a couple of bills. Safety first dont depend on someone elses word that the tune wont grenade ur ****
Sent from my LG-D415 using Mustang Evolution mobile app
03 GT 13.4 @ 117MPH best 2v 4.6 w/ auto
Check out my Garage info for what I am installing at this moment~
retiredvet is offline   Reply With Quote
Old 08-14-2015, 11:11 PM   #11
Does the car have a wideband? If not I would get one ASAP. Also run a few datalogs.
Old 08-14-2015, 11:13 PM   #12
retiredvet's Avatar
Based on what the shop finds they can best recommend what are the easiest and safest blower friendly upgrades
Old 08-15-2015, 08:43 AM   #13
It does not have a wideband. I was going to get that and a boost gauge. Do you know a good set to buy that won't hurt the wallet?
Old 08-15-2015, 03:46 PM   #14
So I plugged in my SF3 tuner and it started doing a download. Afterwards I started the car and it's started smoking and running poor idle. I shut it off. I then used the tuner to put back to factory ecu and nothing has changed. I can't even drive it. Any ideas?
Old 08-15-2015, 08:52 PM   #15
retiredvet's Avatar
Told u to take it to a tuner first not to trust the word of the guy u bought it from. Have it towed to tuners shop if its running that bad
Old 08-15-2015, 09:51 PM   #16
I got it figured out. Re-ran the tune that was on there and it runs good now. I will get it to a tuner ASAP though. Do you have any recommendations for decently priced gauges?
Truck will be forsale next spring. What to get next? sonic04edge The Bar 28 09-26-2006 08:45 PM
Next Gen Electric Supercharger??? Rellik Pre-2005 V6 Mustang 31 10-13-2003 08:03 AM
So, I'm going to a rave next weekend... .:DarkEntity:. The Bar 3 09-14-2003 12:37 AM
What should I get next dapack69 Pre-2005 V6 Mustang 11 08-19-2003 09:20 AM
HELP, NEED TO KNOW WHAT TO DO NEXT mheath Pre-2005 V6 Mustang 6 07-27-2003 05:01 PM
07:07 AM
