Upgrading to 31 spline axles. Question? - Mustang Evolution
Old 08-16-2015, 11:07 AM   #1
phatspeed7x's Avatar
I know my 2004 GT has 28 spline axles from the factory.
I have a set of rear 8.8 axles from a 2010 crown Victoria at work. Does anyone know if they are 31 spline and could they be installed in my Mustang? They were ordered for the local police department but they sold the car before they were used.
Sent from my SM-G900P using Tapatalk
~2004 GT with Bolt ons~
phatspeed7x is offline   Reply With Quote
Old 08-16-2015, 06:50 PM   #2
You can count the splines on the end of the axle shaft to determine if is a 28 or 31.
I suspect that the rear end on a Vic is wider, so it likely has longer axle shafts.
Old 08-17-2015, 06:24 AM   #3
IIRC the length is different. Why do you need 31 splines btw?
Old 08-17-2015, 08:23 AM   #4
If the axles were to fit (which I'm pretty sure they aren't now due to length different) I was going to upgrade axles with a different limited slip. But now I'm just going to keep my stock axles. I ordered the Ford Racing rebuild kit for my factory limited slip. Gears and rebuild should be done next month I hope.
Upgrade to 31 Spline LSD and axles? Polar Bear 1996-2004 Mustang GT 8 12-13-2012 06:17 PM
stock axles are 31 spline ak_stang 2011-2014 V6 Mustang 4 07-04-2012 07:11 PM
2002 mustang gt axles-auto transmission Venemous02GT 1996-2004 Mustang GT 2 05-09-2012 09:31 AM
axles STEVE Pre-2005 V6 Mustang 9 10-07-2004 05:50 PM
06:10 AM
