Most noticeable suspension mod - Mustang Evolution
Old 08-16-2015, 06:51 PM   #1
keeney35's Avatar
Going to the strip this weekend and have a little $ to spend. What's the single most noticeable suspension mod to help me hook a little better?
Subframe?
I already am lowered and have Koni struts and shocks
keeney35 is offline   Reply With Quote
Old 08-16-2015, 06:56 PM   #2
alterego's Avatar
lift bars?
alterego is offline   Reply With Quote
Old 08-16-2015, 07:04 PM   #3
keeney35's Avatar
Those are lower control arms aren't they?
Old 08-16-2015, 07:46 PM   #4
No need for adjustable lower control arms. Get a set of MM lower control arms, subframe connectors are important too. The stock chassis is pretty damn weak. Easy to twist.
Old 08-16-2015, 08:23 PM   #5
keeney35's Avatar
Is there anything that will give me a noticeable bump for hooking or just wait and get a lot of stuff at once
Old 08-16-2015, 08:33 PM   #6
alterego's Avatar
When I put south side lift bars on my old car I couldn't believe how it felt on launch. But I already had sub frames.
Old 08-16-2015, 08:36 PM   #7
alterego's Avatar
They are not adjustable control arms. They lower the mounting point and add leverage to the rear.Click image for larger version
Name:	ImageUploadedByMustang Evolution1439778987.835490.jpg
Old 08-17-2015, 06:15 AM   #8
^Those are relocation brackets, we do not need them on 05-down cars. Although I'd trade the 04-down 4 link for the 05+ rearend setup anyday.
For just hooking up a little better on the cheap, Steeda lower control arms are as good as MM (in my experience), cheaper and help hooking up. That along with subframes. If you need ground clearance or think you ever might want to run a side exhaust then get the Spintech subframes. Not too many ppl know that subframe but its got max ground clearance. Global West is another real good one and they sell a jacking rail/matrix setup for theirs too.
Although if one runs a TA/PHB setup that will sit lower than the subframes anyway. Which is another reason to run the 5 link or IRS
Old 08-17-2015, 06:31 AM   #9
Panther140's Avatar
So whats going to be the best for cornering? I would also like to know (IRS car here)
Tires are the most obvious but lets omit that option
Panther140 is offline   Reply With Quote
Old 08-17-2015, 06:34 AM   #10
For you?
FTBR kit to sort the rear, coilovers on all 4 corners, CC plates and subframes.
And a good 4 wheel alignment obviously. Gots to get the rear aligned on the IRS cars too.
Old 08-17-2015, 08:21 AM   #11
tj@steeda's Avatar
Getting rid of the rubber parts in the rear suspension will help to plan the tires. The best bang for the buck is the control arm kit.
Steeda 1999-04 Mustang Upper / Lower Control Arm Combo - Made in USA 555-2002 | Free Shipping!
It includes the rear axle bushing in the kit too!
Let me know if you would like to speak with one of our resident drag racing experts!
Best Regards,
TJ
Steeda Autosports
Valdosta, GA & Pompano Beach, FL
Mustang Performance Products
Private Message Me About Special Discount Codes
www.steeda.com
tj@steeda is offline   Reply With Quote
Old 08-17-2015, 09:00 AM   #12
keeney35's Avatar
Thanks TJ I've got Steeda everything on my car lol just nothing suspension wise
Old 08-17-2015, 09:09 AM   #13
Gotta watch those uppers tho. The ones TJ listed are built to withstand a nuclear blast... which is very very bad for the torque boxes as well as binding up the rear suspension around corners. If you are just worried about launching in a straight line and are taking it easy around corners then you can weld the **** out of the boxes/install battle boxes and maybe be ok.
Steeda DOES provide a full solution for the rear tho and that is their 5 link which I will be doing to my 2000 eventually.
All that said, my 2000 Steeda car comes stock with that kit TJ listed so I am going to be very very careful going around corners till I swap it out. If I can get a good deal on some stock uppers or some heim joint uppers I may swap those in temporarily...
Old 08-17-2015, 09:28 AM   #14
Someone say suspension?
Name:	ImageUploadedByMustang Evolution1439825302.875439.jpg
Old 08-17-2015, 10:36 AM   #15
That's not yours is it?
At any rate that is a crazy *** setup, DO WANT!
edit: Ooooh he has the Spintech subframes too! Or custom ones for the side exhaust. Anywho, that is what the Spintechs look like installed.
The greatest most difficult and most expensive mod of all time jbanks 1996-2004 Mustang GT 34 07-02-2011 05:06 PM
very noticeable shaking/bad accel blackonblack Pre-2005 V6 Mustang 6 04-30-2010 07:35 PM
I guess the driver is the most importance mod JROC Pictures and Videos 20 08-07-2007 12:31 AM
POST a pic of the most stupid/worthless/ricer mod you can FIND! SpectorV The Bar 16 06-30-2004 12:27 PM
Noticeable Power from CAI and Dual Exhaust? Stang01 Pre-2005 V6 Mustang 11 07-29-2003 05:17 PM
12:21 PM
