What do you think? - Mustang Evolution
Old 08-17-2015, 10:02 PM   #1
Jheard517's Avatar
What do you think?
2000 gt 5sp. Bbk Lt, bbk xpipe, slp lm1s,bbk 78mm tb, jlt cai, stage 1 crower cams, steeda udp. I put down 287 hp and 290 tq on the dyno. Is that too low for what i have?
Jheard517 is offline   Reply With Quote
Old 08-17-2015, 10:25 PM   #2
keeney35's Avatar
Stock fuel system? Was that before or after a tune?
keeney35 is offline   Reply With Quote
Old 08-17-2015, 10:28 PM   #3
Jheard517's Avatar
Stock fuel system. Thats after the tune
Old 08-17-2015, 10:36 PM   #4
keeney35's Avatar
What do you think?
I've got basically the same mods except stage 3 comp 270's and I'm just a little over 300, have a short throw shifter and some suspension stuff, I think if you do a little fuel system upgrades where it can be under to make a little more maybe you can get it higher with a. New tune
Old 08-17-2015, 10:41 PM   #5
keeney35's Avatar
I've got 47 lb injectors and little higher lph pump so I can feed it more fuel
Old 08-17-2015, 10:44 PM   #6
Jheard517's Avatar
Ok ill look into it. Im thinking about doing a centrifugal over the winter.
Old 08-18-2015, 02:04 AM   #7
Steve96's Avatar
Sounds about right from others with the same mods. I think what i have read with "stage 2" cams (stages are subjective i know) that you are closer to the 300 mark or a little under. Fuel system feeding more fuel with the tune and maybe a plenum you will see 300 or a little more with an agressive tune. You were tuned by lidio right IIRMC? He is known for conservative tunes to ensure everything works right and isnt pushed to the limits of what you have. I bet with a little more agressive tune you could pick up 10hp and be closer to where you thought it would be. Get a sc and you will be very happy im sure of it!
1996 GT
Old 08-18-2015, 08:23 AM   #8
That is what a cammed 99-04 PI motor will make with bolt ons. That's a pretty good number.
That said, if you have the stock 19s you are completely maxing them out right now. Throw some 24s in there and a re-tune and see what she does. Stock pump/lines/rails will be totally fine, just the injectors need upgraded.
Old 08-18-2015, 12:03 PM   #9
Jheard517's Avatar
Thanks guys I appreciate it. Im just gonna throw the SC on it and be done with making power. Sure ill be happy with that.
Old 08-18-2015, 08:28 PM   #10
retiredvet's Avatar
I have what u have but shorty headers, 42lb injectors and
I have everything u have plus ported stock heads, 42# injectors, high flow fuel pump and pro products aluminum intake and really aggressive tune put down 328hp 345tq on 93, bout 10 more on 105
Sent from my LG-D415 using Mustang Evolution mobile app
03 GT 13.4 @ 117MPH best 2v 4.6 w/ auto
Check out my Garage info for what I am installing at this moment~
retiredvet is offline   Reply With Quote
Old 08-18-2015, 10:06 PM   #11
Should have done that in the first place. Will make just as much power with the stock cams as it does with aftermarket cams in a stock motor. Stock rods will let go around the 450 range regardless. Need a built motor to turn it up any higher.
Old 08-20-2015, 08:01 AM   #12
Jheard517's Avatar
You cant say i should have done that in the first place. I want to do more than just throw a blower on it. Thats why i started this build. Its not a budget build so im not worried about the money ive spent. Everthing ive done to the car should help it run more efficient with a blower on it. If after the SC its not enough ill build the motor and turn up the boost.
Old 08-20-2015, 08:38 AM   #13
A supercharger on the stock motor can make much more power than the rods can take so like I said, cam swap and then a blower on a stock engine is a waste of money when you are still limited to the same number in both cases.
This is why you supercharge first and start working on suspension and then build a motor on the side.
Old 08-20-2015, 05:01 PM   #14
Jheard517's Avatar
Yes cause your the build master right? Does everyone follow your instructions? Im not limited when u have money to build js. Sure tour situation isnt like mines.
Old 08-20-2015, 05:08 PM   #15
Jheard517's Avatar
*I
Old 08-20-2015, 05:42 PM   #16
I've wasted enough money myself in the past. Plus you'll need new blower cams later on in the future. Whatever you want to do.
As far as the build master, far from it but I've been doing these cars for 15 years now so I just may have picked up a few things.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 08-20-2015, 06:20 PM   #17
Jheard517's Avatar
I gotcha ya. I stopped listening to peoples advice when they would say google it. So now i dont want to hear what they have to say about my build. Alot of d**** in this group.
Old 08-20-2015, 06:34 PM   #18
jeno's Avatar
Well you asking these guys the advice and opinions then you bash on them since you seem to know the answers then why ask just do what your gonna do and don't ask for opinions when your being the d***
Sent from my Nexus 6 using Tapatalk
jeno is offline   Reply With Quote
Old 08-20-2015, 06:47 PM   #19
Jheard517's Avatar
I never ask what i should do in this thread. I ask about some numbers. You told me what i should do.
Old 08-20-2015, 06:50 PM   #20
Jheard517's Avatar
Read it through. When did i ever ask what to do. You were the one that came out and said you shouldve done it this way js
Old 08-20-2015, 06:52 PM   #21
jeno's Avatar
No they did not tell you what to do you asked what they thought so there opinion is what they gave and they thought should be done whether you agree or not is your choice this is not the other forums these guys who reply have a lot of knowledge and are steering you in the wrong direction so you should ease up on them instead of name calling said my peace and there it is.
Old 08-20-2015, 07:01 PM   #22
Jheard517's Avatar
Never said everyone in hear acts like that. So dont try to defend someone when they were wrong for telling me i waisted my money and i shouldve done it their way. I simply said i dont ask for advice on my build when half the time you hear google it.
Old 08-20-2015, 07:44 PM   #23
jeno's Avatar
Fair enough so let me ask how much have you spent on the bolt ons you have
Old 08-20-2015, 07:57 PM   #24
Jheard517's Avatar
Not sure. Ive never added it up.
Old 08-20-2015, 08:25 PM   #25
jeno's Avatar
Well from what I see you have on the car is say around 2500 to 3000 so in that your HP and tq are low for the money spent if you would of went forced induction for 1 to 2000 more you could be pushing 400 HP to the wheels so yeah I think your numbers are low I'm stock 03 gt had it dynoed and I'm at 235 to the wheels so you see what there getting at you not much more than me
Old 08-20-2015, 08:30 PM   #26
Jheard517's Avatar
Yeah 50hp doesnt sound like alot. But with my set up with a SC ill be more than 400 hp.
Old 08-20-2015, 08:31 PM   #27
jeno's Avatar
Don't get me wrong those numbers are good but if your looking for more power there are better ways to spend your money but at the end of the day it's your car your money
Old 08-20-2015, 08:35 PM   #28
jeno's Avatar
But you have to be careful the bottom end can only handle so much before it lets loose just my opinion @ 400 or so to the wheels is at the limit of the internals without building the motor
---------- Post added at 02:35 AM ---------- Previous post was at 02:34 AM ----------
Are you tuned
Old 08-20-2015, 08:42 PM   #29
Jheard517's Avatar
Im never getting rid of the car. When it gets to that point ill start building my motor, i live in mich. My car is down 6 months out the year.
Old 08-20-2015, 08:46 PM   #30
Jheard517's Avatar
When i bought the car i never said im only going to do certain things. I bought it for my toy and a build. It will always be my outlet for stress.
Old 08-21-2015, 04:35 AM   #31
jeno's Avatar
A stress outlet via the pedal is awesome. Are you running a tune?
Old 08-21-2015, 11:51 AM   #32
Jheard517's Avatar
Yeah i have one from Alternative auto.
you think you have bad wheel hop! fast64 The Bar 4 08-30-2005 12:57 PM
For all you who THINK you have a high post count... SpectorV The Bar 14 12-19-2004 06:00 PM
And you think you have ant problems.. lowflyn The Bar 24 10-13-2004 06:43 AM
So you think you're hardcore... WhiteStang99 The Bar 11 09-13-2004 09:18 PM
So you think you're some know it all car guy! Ken The Bar 20 10-31-2003 06:37 PM
11:56 PM
