Hi i have a problem with my car - Mustang Evolution
Old 08-19-2015, 07:52 PM   #1
When the car is moving on neutral
My rpm moves down and up
Any one know how to fix the problem
Mich is offline   Reply With Quote
Old 08-19-2015, 07:58 PM   #2
First, you should check for any trouble codes. There may be a code even if the Check Engine Light is NOT lit.
And secondly, check for any vacuum leaks.
Old 08-19-2015, 08:02 PM   #3
Don't have the check engine light
But i will check for any code
And check for leaks
The other day unscrew the tps sensor
Old 08-19-2015, 08:11 PM   #4
Did this begin after you unscrewed the idle sensor?
Old 08-19-2015, 08:17 PM   #5
No
Only sometimes have this problem
But
The rpm go low then up and down
You dont know if this can damage the engine
Old 08-19-2015, 08:31 PM   #6
It shouldn't, necessarily, hurt it but it is better if it idles at around 750 rpm's.
How long has it been since the engine was last tuned up and the filters changed and the Throttle Body and MAF sensor last cleaned?
Old 08-19-2015, 08:34 PM   #7
I only did the oil and filter i havent clean the throttle body
Old 08-19-2015, 08:41 PM   #8
Like I said, check for any codes first.
If there are none, we can walk you through the list of maintenance items and, hopefully, get your idle straightened out.
A dirty TB can be a cause as well as the Idle Air Control valve, and a number of other things!
Also, if you are going to have a parts store check the codes, have them test your charging system while they are at it.
Old 08-19-2015, 08:47 PM   #9
Ok will check all the thing you say thanks man
Which car to put in the garage? Yes a GOOD problem to have! fury88 General Mustang Discussion 4 11-04-2014 11:02 AM
I have problem with my car the oil pressure is low Mich 1996-2004 Mustang GT 39 08-10-2014 12:14 PM
Big problem-easy find, small problem-hard to find Dnraiders General Mustang Discussion 0 08-30-2011 11:10 AM
What car would you rather have if you could have either??? 1965 Ford Mustang or 1963 Mercury Comet? colton Classic Mustangs 3 08-29-2009 12:40 PM
» Members Mustangs
Red
Red89
His
sparky9445
Add your Mustang
11:39 AM
