Considering a Kenne Bell - Mustang Evolution
Old 08-21-2015, 12:24 PM   #1
Considering a kenne bell 2.1 for my 03 gt in the next couple months. Anyone on here have a kb on there 2v? This is my dd and just wanna have some street fun, and boost seems the best way to go. After researching I think the kb will suit me better then turbo or centrif. Type. Anything I should know about the swap? 180000 on her so I'll prolly sc it,save a little more and get a junk yard 4.6 and do a forged bottom end because I'm sure the stock bottom can't hold up to 14 psi. Would 9 psi be safe with that many miles for a little while?
Also what other parts would be beneficial to add to the build? Would the stock clutch hold up to the 400+ claimed hp from 9lb? Kit comes with injectors and fuel pump booster but should I just get a higher flow pump? Maf? Heads? Would shorty headers or long tubes be best? Cars stock now except for or x and flows.
Sent from my iPod touch using Mustang Evolution
Calebnc302 is offline   Reply With Quote
Old 08-21-2015, 01:51 PM   #2
2300turboford's Avatar
Kenne bell is way over priced I'd get a inner cooled procharger
Old 08-21-2015, 01:53 PM   #3
natestang07's Avatar
He doesn't want a centri
Old 08-21-2015, 10:21 PM   #4
You do realize the Kenne Bell is cheaper than the Procharger and he said he didn't want a centri right?
Old 08-21-2015, 10:29 PM   #5
retiredvet's Avatar
9psi intercooled 2.1... plug and play.. once you rings go grab a 700 dollar junkyard special, change the clutch and put her back in
Sent from my LG-D415 using Mustang Evolution mobile app
03 GT 13.4 @ 117MPH best 2v 4.6 w/ auto
Check out my Garage info for what I am installing at this moment~
retiredvet is offline   Reply With Quote
Old 08-21-2015, 10:43 PM   #6
Basically what everyone's saying. Low boost for now. Then engine swap, low mileage, and maybe forge the internals. And up the boost; then you'll have one mean car.
Pick your poison.
Recon is online now   Reply With Quote
Old 08-22-2015, 10:56 AM   #7
olerodder's Avatar
Region: Oregon
I have 0 experience with 2v....only 4v.
I had a Kenny Bell on my 97 Cobra. It worked fantastic although this was over 15 years ago. I started out at 6, then 8.....when I tried 12 I broke a ring land off of #8 and #6.
After that I put a good set of rods and pistons in it and started breaking the rear end. Sold it shortly after.
Like was said, start out with low boost and if you want more the whole drive train will need to worked on..trans....driveline.....rearend.
Old 08-22-2015, 12:35 PM   #8
At the stock motor's power limit of about 425-450rwhp, the transmission will be fine if its in good shape and so will the rear. Its when ppl put them in cars with a lot of miles that problems crop up.
When I eventually get this stupid motor swapped in my 2000 it will still be a stocker pullout from the JY with 38k miles at $575 shipped to my door, stock trans, Exedy Mach 400 11" clutch, stock T45 and stock rear. I do no forsee any issues as far as driveline durability but if something does break then I suppose that's just an excuse to upgrade it lol.
major f#$kin problem Smoke 2011-2014 Mustang GT 26 08-05-2012 06:27 AM
Considering these wheels for the '06... bbunt302 Mustang Wheels & Tires 5 06-20-2006 07:42 PM
im considering the paint 98% done SrATEX Pictures and Videos 15 08-23-2005 05:33 PM
Considering a Commuter Car Ken The Bar 21 08-21-2005 11:21 PM
Video for anyone considering Rally Car Racing n8r The Bar 11 04-07-2004 01:22 AM
10:07 AM
