Steering problem - Mustang Evolution
Old 08-21-2015, 08:04 PM   #1
XxFLoridaboYxX's Avatar
Steering problem
I've replaced struts,ball joints,springs,outer tie rod end,swaybar end links and bushings.. my steering is so loose and I still have a really bad screeching/creaking noise up front. It's hard to drive in a straight line that's how bad it is and it does its own thing around corners what do I replace next ? Steering rack bushings ? Inner tie rod ends ?
XxFLoridaboYxX is offline   Reply With Quote
Old 08-21-2015, 08:20 PM   #2
jeno's Avatar
From all your symptoms sounds like your rack and pinion is shot just had a thread like this but they don't have those issues
Sent from my Nexus 6 using Tapatalk
---------- Post added at 01:20 AM ---------- Previous post was at 01:19 AM ----------
Steering
If you are having a problem with the steering rack and pinion, your steering wheel will have a loose feel to it. The car may also wander on the road when you are driving, moving slightly to one side or the other instead of traveling in a straight line. Steering will seem harder than it should, and the car will not respond well to the movements of the steering wheel. It may also be harder to turn the car in one direction than the other. Another sign of a problem is that the car will be harder to steer in the morning than later in the day. You may also find that the steering wheel does not return properly to its normal neutral position after you have made a turn.
Noise
According to the New Jersey Division of Consumer Affairs, sounds such as thudding, clunking, or a persistent knocking can be warnings of a loose rack and pinion steering system. If you hear these types of sounds as you drive, you need to get the system checked out.
Tires
Unusual tire wear is another symptom of a steering rack and pinion problem, though there are other conditions that can cause uneven tire wear. If your tires show uneven wear, where they are more worn on either the inside or the outside than on the rest of the tire, you should suspect a rack and pinion problem.
Leaks
If you find that your car seems to be leaking fluid from the front end, it could be a leak from the rack and pinion steering system. If you want to verify where the fluid is coming from, put some newspaper or cardboard under the boots of your rack and pinion system. If the fluid drips from the boots, you will know that your rack and pinion steering system is compromised. Most likely you will see at least some of the other symptoms listed in this article together with a fluid leak.
jeno is offline   Reply With Quote
Where can I find steering damper for 66 manual steering? Daniod9 Classic Mustangs 11 11-06-2013 11:19 AM
Steering wheel shaking, power steering? toro 2011-2014 V6 Mustang 3 05-04-2013 07:31 PM
Can you interchange a 1965 mustang steering wheel with a 1967 steering wheel? gruffudd91 Classic Mustangs 1 08-26-2009 05:38 PM
Steering problem kercolla New Member Introductions & Greetings 2 08-21-2009 05:35 PM
Steering problem need help! fastlane350 Pre-2005 V6 Mustang 1 03-19-2008 07:31 PM
12:04 AM
