Tallest sidewall that will work? - Mustang Evolution
Old 08-22-2015, 08:28 AM   #1
Panther140's Avatar
I have 2 sets of rims right now for my car. Im thinking about getting some 4.10s or 4.30s for the rear diff, but I drive interstate at 80 so much that I am hesitating.
My idea is to get some very tall sidewalls on my spare set of 17" rear wheels. That way it is effectively geared up again for when I have to do a long trip. I could just jack the car up and switch the wheels before I head out for the weekend
What do you guys think about running a 245/65-17 on the back? It probably would hook better than a lower profile tire anyways lol. The outside diameter would be increased by 4cm
Panther140 is offline   Reply With Quote
Old 08-22-2015, 12:10 PM   #2
retiredvet's Avatar
Sidewall wont wrinkle on launches with any radials. Its all about the tire compound. That said the difference between 4.30 and 4.10 on your et's is negligible and since you highway drive always opt for the higher gear ratio for streetability. If it was a dedicated weekend warrior maybe and then only if you had an auto not with a manual
Sent from my LG-D415 using Mustang Evolution mobile app
03 GT 13.4 @ 117MPH best 2v 4.6 w/ auto
Check out my Garage info for what I am installing at this moment~
retiredvet is offline   Reply With Quote
Old 08-22-2015, 01:09 PM   #3
Panther140's Avatar
Sidewall wrinkle isnt what I was getting at. Taller sidewall = bigger radius = bigger flatter contact patch on the ground
Higher gear ratio is what the taller tires would effectively do and they would be used on the highway.
So what is the tallest tire you think I could put on without damaging the well?
Old 08-24-2015, 07:59 AM   #4
I'm assuming these are 17x8s correct? You can effectively get away with a 27" tall tire out back if you are going for drag strip. I had a set of 26.6" tall tires in my last car that was lowered and they fit fine.
Just get on tirerack and see what the actual overall tire diameter is going to be of whatever you choose.
That said, a 255/45/17 is a very nice tire to go with at 26.1" and was an OEM size for that rim (on 94/95 Cobras). Stick it with some 4.10s and your .68 final overdrive in that Cobra and you should be able to do a decent clip on the highway without too many RPMs.
Hit up tirerack like I said and then google "RPM calculator" and you can plug in all your info and see about what your RPMs will be.
edit: Also be aware that too much size difference between the front and rear as far as diameter is going to cause your ABS controller to kick off and stop working and you'll have that light on the dash.
Is this Nail to close to the sidewall for repair? Seebz13 Mustang Wheels & Tires 23 07-02-2014 09:40 PM
Tallest tire size mrsneakyz28 Mustang Wheels & Tires 9 03-08-2014 04:59 AM
Winter tire sidewall height mrsneakyz28 Mustang Wheels & Tires 0 03-06-2014 10:42 AM
Ratio/Sidewall OzzyLiriano Mustang Wheels & Tires 13 02-06-2013 10:29 AM
Tire size comparison for 17s (sidewall wise) SpectorV 2005-2010 Mustang GT 3 11-10-2009 05:09 PM
10:40 PM
