Intake manifold swap - Mustang Evolution
Old 08-28-2015, 03:28 PM   #1
Faststallion98's Avatar
So I have a ford racing manifold from a town car that I thought would work but the coolant tube that runs underneath is in the way. I had a crappy dorman manifold and it fit fine. What I would like to know is if there is anything I can do to make it work and will one from a new edge fit? My car is a 98 with the pi swap. Any suggestions would be greatly appreciated.
Faststallion98 is offline   Reply With Quote
Old 08-28-2015, 03:54 PM   #2
jeno's Avatar
Your going to need the ffrp pi intake
Sent from my Nexus 6 using Tapatalk
jeno is offline   Reply With Quote
Old 08-28-2015, 06:50 PM   #3
Well that sucks for me
Old 08-30-2015, 11:30 PM   #4
The PI manifold should be the same. I know the one that came off my Vic motor is although I can't use it because its got warping under the tstat housing. The Vic/Marquis/Towncar intakes have a foam padded box around them that is not on the Mustang intakes and would need to come off.
Also be aware that the coolant tubes on the Vic/variants and the Mustang are not the same because of that stupid box the lower part of the intake sits in.
Old 08-31-2015, 08:54 AM   #5
My problem is the coolant tube. Is there anyway to modify it to work?
Old 08-31-2015, 12:28 PM   #6
Solved my own problem
Old 08-31-2015, 02:12 PM   #7
jeno's Avatar
How did you fix it
Old 08-31-2015, 09:35 PM   #8
I forgot that I had a coolant tube I had pulled from a new edge a few years back and it offsets the tube to the left of the motor to clear the lower part of the intake
Old 08-31-2015, 10:44 PM   #9
Like I said, the intakes are the same but the coolant tubes are not. I've got a Vic motor on a stand in my garage right now lol.
intake swap on a 94 gt intake kell97Gt 1979-1995 Mustang GT 5 10-14-2012 01:09 PM
Boss intake manifold and the stock intake Yellow50 2011-2014 Mustang GT 43 04-26-2012 06:30 AM
Intake Manifold vs Intake Man-child jbanks 1996-2004 Mustang GT 17 08-02-2011 04:55 AM
95 Intake manifold. Calston31 Pre-2005 V6 Mustang 6 12-05-2004 05:42 AM
Intake manifold and cylinder head jwscorpio Pre-2005 V6 Mustang 4 02-27-2004 06:49 AM
10:12 PM
