Finally getting to the cam install - Mustang Evolution
Old 08-30-2015, 06:24 PM   #1
keeney35's Avatar
I've had my comp 270 cams since February and I'm finally fed up with staring at them in the box...
I have the cams, all new gaskets, seals and installation hardware. Comp beehive springs and retainers as well as adjustable crank gears for the timing..
My question is this. I'm running 19lb injectors. I have a set of new 47lb for future boost plans but will I be maxing out my 19lb injectors with the cams and my other mods?
Anything I need to know for the install to make sure the mechanic knows?
Also I've got a new SCT x4 and have a MPT tune on the way to me.. Once I get them installed I'm gonna have MPT make me another one for the cams and possibly the injectors if I need to..
keeney35 is offline   Reply With Quote
Old 08-30-2015, 07:11 PM   #2
Slater2111's Avatar
Yea you should install those injectors. Maybe not that much LB per hour but it will max out those 19lbrs
Slater2111 is offline   Reply With Quote
Old 08-30-2015, 07:15 PM   #3
keeney35's Avatar
MPT said they could just adjust it for the 47lb injectors but By maxed out do you think that means not drivable lol unless the 47lb and tune is on it?
Old 08-30-2015, 07:30 PM   #4
Slater2111's Avatar
Yea 19lb will be maxed out and won't be able to supply enough fuel. If MPT will tune for the bigger injectors might as well put those in.
Old 08-30-2015, 07:55 PM   #5
keeney35's Avatar
It's my daily lol that's the issue so it's gonna have to be done pretty quickly
Old 08-30-2015, 11:14 PM   #6
DetroitMuscle99's Avatar
I had 19lb injectors and I did a stage two ported head and stage 3 comp cam and my injectors weren't maxed out, and I got a dyno tune.
This is why we play the game... to separate the contenders from the pretenders!
DetroitMuscle99 is offline   Reply With Quote
Old 08-30-2015, 11:17 PM   #7
19lb is just about maxed out stock. I don't see how they could be used with cams. 47 will be overkill for now but will work as long as the tune accounts for them. You can use them later on for the boost. 42 is about good for 425-450whp so 47 is enough unless you build it.
Old 08-30-2015, 11:26 PM   #8
Talk to MPT make sure the 47s are good but don't run the 19s, they're at 90% duty cycle on a stock application and there is a reason Ford went to the 21s in 2002.
Old 08-31-2015, 06:44 AM   #9
keeney35's Avatar
So is mine 21 then since I have an 04?
Old 08-31-2015, 06:56 AM   #10
Slater2111's Avatar
You have 21s if you haven't changed them. I was under the assumption you had 19s because you said you did. 21s will be near maxed out too.
Old 08-31-2015, 07:10 AM   #11
Slater2111's Avatar
Double post
Old 08-31-2015, 09:59 AM   #12
Yes you have 21s. They might be ok with cams. Might.
Old 08-31-2015, 10:06 AM   #13
parkerz28's Avatar
21s are pink 19s are orange just look at your injector and you will know for sure
Sent from the back seat
parkerz28 is offline   Reply With Quote
Old 08-31-2015, 03:13 PM   #14
keeney35's Avatar
Got quoted 600-700 for the cam install with the valve sprigs and all, and degreeing them of course.. Sound accurate?
Very reputable performance shop near me
Old 08-31-2015, 03:20 PM   #15
parkerz28's Avatar
I was quoted similar... But I was also replacing timing chain guides etc...
Sent from Rapinators trunk
Old 08-31-2015, 03:27 PM   #16
keeney35's Avatar
I'm not unless they think I need it.. I'm still just below 100k so mine should be okay..
If not I can replace them another time on my own
Old 08-31-2015, 03:34 PM   #17
parkerz28's Avatar
I here you... I'm at 90k and figured they have to be removed anyway why not replace them... Either way it's a decent price... I decided to go boosted that's the only reason I didn't go cammed... Yet lol
Old 08-31-2015, 03:40 PM   #18
keeney35's Avatar
I'm gonna change the timing set at school when k get to my engines class lol
Old 08-31-2015, 03:40 PM   #19
parkerz28's Avatar
Nice 👍🏻😎
Old 08-31-2015, 09:43 PM   #20
keeney35's Avatar
God I can't wait to get these in next week lol I've had these cams since February and have been waiting ever since to get them in... One more week and I'll thumpin
Old 08-31-2015, 09:55 PM   #21
natestang07's Avatar
That's like how long my cams have been on the shelf
Old 08-31-2015, 10:14 PM   #22
keeney35's Avatar
I'm sick of looking at him, it was the same thing with my headers then I finally had enough beers and convinced myself to install them myself lol
Old 09-04-2015, 10:02 PM   #23
Steve96's Avatar
Your car is going to sound amazing with the new cams. That install price sounds good for the labor. I was quoted $600 for labor and degreeing, spring install, etc. And was a very good performance shop as well. Total was close to $1k with the cams, and new springs, etc. It was a huge quote tho so I dont know if they were giving me a break since it was for heads (PI machined and installed, PI intake and install, cams of course, injectors, and a tune).
1996 GT
Old 09-04-2015, 11:02 PM   #24
keeney35's Avatar
I'm hoping it sounds good..
I'm freaking my self out tho..
The shop is going to make sure they are degreed and I got adjustable gears for the timing.. And MPT is emailing me a tune for the cams and all my other mods.
Idk why I'm worried but I hope the tune and the degreeing the shop does blend.. Idk if either one affects the other but it's making me think
Old 09-05-2015, 01:01 PM   #25
thyreaper's Avatar
They do effect each other but only negative if the shop does not degree them properly, what cams did u get? Cuz ive seen alot of cams have ptv issues when degreed properly to the cam spec but usually only stage 2s or bigger have problems and that also depends on the manufacture also, ive also seen stage 2s ( same cams) work fine in other cars and not work in some... Weird how it all works out when its suppose to be the same motor lol... But that shows u that u should either dyno tune or email tune that was datalog'd because no 2 cars are the same even with same mods
thyreaper is offline   Reply With Quote
Old 09-05-2015, 01:42 PM   #26
keeney35's Avatar
They are comp stage 3 270's MPT sent me a base tune but want me to data log so they can get it right on
Old 09-06-2015, 12:51 PM   #27
phillip433's Avatar
If you don't mind me asking. How much is the mpt tune
phillip433 is offline   Reply With Quote
Old 09-06-2015, 01:03 PM   #28
Slater2111's Avatar
Tunes that don't require data logging which most won't are $70. Updates of those are $20. Cam tunes and supercharger tunes are extra.
Old 09-06-2015, 01:49 PM   #29
keeney35's Avatar
Also I picked up some timing chains, guides and such to have piece of mind that that's new.. Reusing stock cam sprockets but got adjustable crank gears
Old 09-07-2015, 08:13 AM   #30
thyreaper's Avatar
Ok, well as long as u dont have ptv issues then ur good
Old 09-07-2015, 08:54 AM   #31
Yep 270s often have to be installed retarded because they are too close on stock heads.
Sent from my LG-D801 using Mustang Evolution mobile app
Old 09-07-2015, 08:57 AM   #32
Chrism's Avatar
Which one do I have ? Since I have a 14 v6
Chrism is offline   Reply With Quote
Old 09-07-2015, 10:22 AM   #33
keeney35's Avatar
I'm sure the shop that's doing them knows what to do, he's a comp dealer and he's a big drag racing guy but when I drop it off Wednesday I'll double check
Old 09-07-2015, 09:50 PM   #34
phillip433's Avatar
That makes me wonder. I have stage 2 cams and With the stock 19lbs. At times my car will lean out when wot and the idle acts up a lot. Could that be the injectors?
Old 09-07-2015, 10:14 PM   #35
keeney35's Avatar
Depending on what other mods yes.. I have near future plans which is why I went so big
Replaced cam pos sensors, still getting CEL wereKEV 2005-2010 Mustang GT 4 10-05-2012 02:02 PM
Getting away from E303 cam... Beastynotch 1979-1995 Mustang GT 9 01-23-2012 09:49 AM
3.8 V6 Comp Cam Performance Cam nmaraijko Mustang Parts for Sale and Wanted 0 11-15-2006 07:11 AM
Cam Cores needed for RDMotorsport cam GP RGR Mustang Parts for Sale and Wanted 3 03-05-2005 05:53 AM
02:20 PM
