Max tire size - Mustang Evolution
Old 08-31-2015, 11:39 AM   #1
Max tire size
Can I fit a 275/35/17 onto a 17x10 wheel?
Quadracer18 is offline   Reply With Quote
Old 08-31-2015, 11:45 AM   #2
keeney35's Avatar
Yes, I've got 315 on my 10.5 in wheel you'll be fine..
---------- Post added at 11:45 AM ---------- Previous post was at 11:44 AM ----------
I've got 275's on my front and they are only 9"
keeney35 is offline   Reply With Quote
Old 08-31-2015, 05:11 PM   #3
Mile high JDF's Avatar
A 275/35R17 is gonna be a very short sidewall
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 08-31-2015, 11:19 PM   #4
Panther140's Avatar
275 is probably going to be noticably stretched on most 10" wheels when you are running almost no sidewall like that.
Panther140 is offline   Reply With Quote
Old 08-31-2015, 11:43 PM   #5
keeney35's Avatar
I agree, if it's a 10" wheel at least do a 285/295. But I would say 305 would be my choice.. I've got the extra .5" so I run a 315
Old 09-02-2015, 01:34 AM   #6
joe_117's Avatar
I run 285 on my 9.5s
joe_117 is offline   Reply With Quote
Old 09-02-2015, 09:20 AM   #7
275 is fine no a 10" rim depending on the brand. Most BFGs will fit great, something like a Nitto or a Sumi will be stretched.
Here is a BFG 275 on a 10" wide rim
As you can see, the fit is perfect but this particular BFG 275 is more like a 295 or a 305 in Sumi/Nitto size. You can check actual widths and other specs on tirerack.
As far as a 275/35/17, that is WAY too short of a tire, the middle number, 35 in this case, is not a static number it is a percentage. 35% of 275mm. The correct OEM height of 25.7-26.1 for a 94-04 Mustang is achieved with a 275/40/17.
Old 09-02-2015, 11:02 PM   #8
Steve96's Avatar
Scotty what were the 275 BFGs that you were running? Were they the BFGs street comp 2s? Or something like that? I was thinking of looking into a set for my rear 17x10s and moving my current 275 40s up front. If its true they run wider then i would still have a little wider tire out back
1996 GT
Old 09-02-2015, 11:23 PM   #9
These
http://www.tirerack.com/tires/tires....omCompare1=yes
They are massively wide for a 275, you can click on the specs and see the tread width is a full inch wider than normal. And you can't beat the price. A lot of local places will carry these too, I know my local shop would do these for like $160 each installed. Remember you have to pay tirerack shipping too at like $20/tire.
I also saved a lot of money by putting 235s up front on 8" wide rims on that car. All the tires in that specific BFG line run big. A 235 wide sits perfectly flush with an 8" Mustang wheel. Not "hella flush" or some other stupidity, straight up and down. And they don't lip out past a 94-98 fender too running 8" wide like 9s can.
Old 09-02-2015, 11:25 PM   #10
Steve96's Avatar
These
Thank you very much for the info!! Ill check them out and local too
1996 GT
Old 09-02-2015, 11:32 PM   #11
Hell, I may have just found a way to get those Steeda rims much closer to an AM combo pack price.
http://www.tirerack.com/tires/tires....C2XL&tab=Sizes
These are sized like a 285/35/18 for a lot less money than you'd pay for that size normally.
This is why I tell everyone about these tires, they are really good performers too and the ride quality is great. And they are quiet and smooth.
Max tire size PiojoA7x Mustang Wheels & Tires 9 09-12-2014 08:13 PM
Tire size and rim size 96gt Lios 1996-2004 Mustang GT 9 04-22-2012 11:33 PM
What is the max tire size for a mustang 1994 special edition? botulf87 Mustang Wheels & Tires 2 03-19-2010 09:55 AM
Wheel size & tire size help needed for newbie rayramos Mustang Wheels & Tires 14 09-21-2009 12:45 PM
Max Tire size ArmyStangGT Mustang Wheels & Tires 7 08-04-2009 10:34 AM
09:29 AM
