Vortech supercharger pulley size - Mustang Evolution
Old 09-01-2015, 10:46 AM   #1
So my car is completely stock aside from a vortech v2 supercharger, kenne bell boost-a-pump, cold air intake, h-pipe and pro chamber mufflers.
I believe my pulley is around 3.5". Can I safely put a smaller pulley on this car without worry that I will damage the motor or supercharger? I do NOT have an intercooler on this car either.
I've heard some say that the 2003 GT engine can only take 400 hp at the crank before its close to running a rod through the block. I also heard that without an intercooler, you shouldn't run too much boost.
What kind of hp gains would I see from utilizing a 3.13 pulley?
Quadracer18 is offline   Reply With Quote
Old 09-02-2015, 08:38 AM   #2
You need to figure out exactly what pulley is on there now for one...
Two is that you need to make sure you are running a stock crank pulley to make sure you are actually going to run the boost number you want.
Third is, get with a tuner and talk to them. You can't just toss a new pulley on without a tune anyway and a good tuner will be able to recommend a correct pulley size based on your mods and desired power level. Non-intercooled should be limited to 6-8 psi anyway.
Belt length for vortech gt with 3.33 pulley Dustin541 1996-2004 Mustang GT 6 01-17-2014 09:36 AM
Vortech S/c pulley size? 99redbeast SVT Mustang 5 11-19-2011 12:48 AM
Polished water pump pulley and alt pulley for 01-04 4.6 2v Everett Mustang Parts for Sale and Wanted 1 03-17-2011 02:52 PM
supercharger pulley size bigpomps Pre-2005 V6 Mustang 0 08-02-2005 01:15 PM
Vortech RR Ultra Grip Pulley blownsix Mustang Parts for Sale and Wanted 0 01-24-2005 10:59 PM
11:42 PM
