Suspension bundle worth it? - Mustang Evolution
Old 09-04-2015, 04:26 PM   #1
keeney35's Avatar
Friend of mine is selling this Team Z kit.. Is this worth it? Good products? Better than my stock rear suspension?
Name:	ImageUploadedByMustang Evolution1441401961.989533.jpg
keeney35 is offline   Reply With Quote
Old 09-04-2015, 05:31 PM   #2
thyreaper's Avatar
How much he want for it? And i was always under the assumption that u need leave the rear upper control arms stock until u reinforce ur torque boxes
thyreaper is offline   Reply With Quote
Old 09-04-2015, 05:56 PM   #3
keeney35's Avatar
600$
Old 09-04-2015, 07:35 PM   #4
fenixignition's Avatar
i think the torque boxes are fine up to a certain horse power. if i had to guess, i would say about 400 hp before requiring an upgrade.
2002 GT 5sp. 16x,xxx miles
Old 09-04-2015, 07:47 PM   #5
keeney35's Avatar
I'm closer to 330 so I'm good there
Old 09-05-2015, 01:47 AM   #6
I wouldn't run aftermarket UCAs without reinforcing the torque boxes. As for the parts. Team Z is a great brand, if the focus is drag racing. It all depends on the goals of the car.
Old 09-05-2015, 01:58 AM   #7
keeney35's Avatar
It's a daily driver, see's the drags strip a few times a year, definitely not a autocross car, but I do want it to at least take corners better or the same as it does now
Old 09-05-2015, 02:07 AM   #8
I'd skip it.
Old 09-05-2015, 01:49 PM   #9
thyreaper's Avatar
Theres guys with stock hp levels launching at the strip and ripping the torque boxes right out ive personally seen it done cuz guy had uca's along with the lowers and a sticky tire and all he had where stage 1 cams, should of heard it made me cringe lol... Now if ur not ever launching hard in first or if ur just spinning then it dont matter what u do but when u start putting the power down it becomes a problem with uca on stock boxes, only my lower boxes are reinforced because my rear suspension dont use the upper ones
Old 09-05-2015, 05:56 PM   #10
Just go Torque Arm like I did. No more uppers
Old 09-06-2015, 05:54 AM   #11
Torque arm alone and I can remove uppers?
Sent from my SM-G920V using Mustang Evolution mobile app
Old 09-06-2015, 02:35 PM   #12
To install a torque arm, it requires weld in subframe connectors and something to control the lateral movement of the axle (i.e. Panhard Bar or Watts Link). Also really want to have lower control arms and heavy duty rear springs. Then you get to remove the upper control arms, as well as the quad shocks.
Old 09-06-2015, 10:16 PM   #13
That's actually the setup that relocates the uppers to a more optimal angle for launches. Setups like this are very good for drag racing where you need to retain a 4 link for a class that requires it. You will not be taking corners with any sort of confidence with this setup tho, as with any 4 link really. You want to do the rear suspension on the "cheap" and you go with a single Heim jointed upper control arm in a reinforced box and a panhard bar and a good set of lowers also with reinforced boxes. This is called the "poor man's 3 link" and it isn't exactly super cheap tbth.
2000 Mustang GT Steeda #0048
Old 09-06-2015, 10:34 PM   #14
keeney35's Avatar
I'm thinking mm subframes, lca for starters then maybe a torque arm... What's everyone's opinions on aluminum driveshafts? Other Than they look nicer than the rusty stock one
Old 09-06-2015, 11:14 PM   #15
More of a looks thing or to replace a messed up stocker for the DS.
Also recommend Steeda Subframes for traditional ones, they're actually better than the MM ones are oddly enough. Steeda LCAs are also just as good from my experience and cheaper.
Torque arm needs a PHB in before or at the same time or its not usable.
There is also the Steeda 5 link or an IRS swap.
Old 09-06-2015, 11:30 PM   #16
keeney35's Avatar
I'm gonna go check out Steeda now, but I was debating a driveshaft just because.. What spline would I need?
Old 09-07-2015, 12:21 AM   #17
My aluminum DS cleared up a lot of vibration when I installed my Torque Arm. Vibrated like crazy above 80mph, after the DS smooth sailing.
Old 09-07-2015, 09:51 AM   #18
I forget don't you have a swapped trans or are you still a t45/3650? If you are a 45/3650 you need a 31 spline. If you are something else you'll probably need to swap your input over which is not a big deal.
Yeah if his is causing vibes its definitely a good idea to replace.
Old 09-07-2015, 11:21 AM   #19
keeney35's Avatar
Well mine vibed' and has some marks where it was hitting my mufflers.
And Scotty it's factory trams just rebuilt
Old 09-07-2015, 11:51 AM   #20
Then 31 spline.
Sent from my LG-D801 using Mustang Evolution mobile app
FOR SALE: PS4 + Extras as Bundle or Part Out Borii FYI Ads | Recently Listed 0 04-13-2014 08:25 AM
Lake Worth GTG (Fort Worth, TX) bigmac3 Regional Mustang Discussion 1 02-13-2014 04:28 PM
Good list? anything worth or not worth getting? Jetsnix Pre-2005 V6 Mustang 58 07-23-2012 12:06 AM
An Xbox 360 bundle deal wiarumas The Bar 3 10-11-2006 10:49 PM
Suspension Packages Save a Bundle! Matt@StangMods Mustang Parts for Sale and Wanted 6 09-28-2005 11:53 PM
09:46 PM
