Where can I find smaller pulley for 360R? - Mustang Evolution
Old 09-05-2015, 02:58 PM   #1
Joshy's Avatar
Hey everyone, I am having trouble sourcing the smaller pulley that the 380R's used in order to push my boost up a little bit on my 02 Roush with the "Roushcharger". Does anyone know where to find it? Will any pulley for a M90 work? I believe it is a 2.8 pulley that I am wanting to upgrade to. Thank you in advance
www.petom.biz
Joshy is offline   Reply With Quote
Old 09-05-2015, 03:42 PM   #2
Rapinator126's Avatar
No need to. The m90 heat soaks so badly especially the design on your car. Car will start loosing power run after run.
🍼and 🌽 fed coyote.
Old 09-05-2015, 06:02 PM   #3
parkerz28's Avatar
He could convert to E85 though that might help s little... Maybe 😐
Sent from Rapinators trunk
parkerz28 is offline   Reply With Quote
Old 09-05-2015, 06:13 PM   #4
Joshy's Avatar
That's not true. I've seen the dyno numbers. It improves power a ton. It's intercooled so it shouldn't be an issue. Even the engineers say it is an amazing mod to do...
It's nothing different than the 380R's. Which were made to be faster. Pulley and tune drasitcly increase horsepower. I have seen one with the pulley, tune, Cai and headers make 402 to the wheels. That's all.
---------- Post added at 06:13 PM ---------- Previous post was at 06:12 PM ----------
It's only pushing 6 #s as it is lol. Another couple won't do much to hurt it
www.petom.biz
Old 09-05-2015, 06:18 PM   #5
Did I say anything about a peak HP #? I'll wait................. No I did not.
I said it will loose power after every run ( meaning it will get slower )
Heat soak is a major problem with the m90 (not my first rodeo partner)
Spinning that little blower faster causes tremendous heat soak. Car will start pulling timing do to it.
There is a lot more you can do that will help vs causing more Heat soak.
A small shot 25-50hp will drastically help with heat soak also.
🍼and 🌽 fed coyote.
Old 09-05-2015, 06:35 PM   #6
CAI, full exhaust, and tune. Or put a different supercharger on it. That's what I'm doing to mine.
Pick your poison.
Old 09-06-2015, 12:35 AM   #7
Joshy's Avatar
🍼and 🌽 fed coyote.
I apologize, I didn't mean to be ignorant. I believe I misunderstood or did not fully understand what you meant. Thank you for your response. I haven't heard any of those issues from those that have done that modification.
Do you mean a shot of nitrous or methanol injection? I have been toying with the idea of the water/alcohol injection.
www.petom.biz
Old 09-06-2015, 12:37 AM   #8
You can do meth injection if you want.
But nitrous has really good cooling capabilities. Something small like the 25-50 will help lot. And be lot better power jump vs the pulley also.
🍼and 🌽 fed coyote.
Old 09-06-2015, 12:48 AM   #9
Joshy's Avatar
Pick your poison.
That is pretty much my plan. Just do bolt ons and then leave it until I have money to do engine work or buy a faster car haha.
www.petom.biz
Old 09-06-2015, 12:49 AM   #10
Joshy's Avatar
🍼and 🌽 fed coyote.
I guess to me nitrous seems dangerous and expensive to use and maintain. Am I wrong? That poor 2V can only take so much haha
www.petom.biz
Old 09-06-2015, 12:52 AM   #11
It's not dangerous. And with something small like a 25-50 shot it won't be expensive. And will still keep you under what the stock motor is good for.
Just the best of both worlds, cooling and a small Jump in power
🍼and 🌽 fed coyote.
Old 09-09-2015, 10:56 PM   #12
Joshy's Avatar
🍼and 🌽 fed coyote.
Wouldn't it cost a lot to have the bottle refilled? Most of the kits I find seem pretty expensive.
www.petom.biz
Old 09-10-2015, 09:27 AM   #13
Zero idea why Saleen/Roush used a 4/6 cylinder roots blower on the 2V. Safety reasons probably.
Then you have Steeda which put a blower capable of 20+ psi on a built V8 on their special cars.
Old 09-10-2015, 09:30 AM   #14
Depends on where you are.
Prices usually range from $2-$7 a pound.
So on a 10lb bottle your looking at $20-$70 just depends on your location.
🍼and 🌽 fed coyote.
Old 09-14-2015, 09:56 AM   #15
Joshy's Avatar
Do you think nitrous would be a lot better than alcohol injection?
www.petom.biz
Old 09-14-2015, 11:34 AM   #16
You mean methanol? Like a Snow kit? If yes then Nitrous x1000.
Old 09-16-2015, 09:13 AM   #17
Panther140's Avatar
Nitrous and Meth injection are good in their own ways.
Water/Meth injection is good because it can be cooling intake charge at part throttle as well as WOT. (This will gain you power across the board even at part throttle) Its also really cheap and easy to refill.
Nitrous is better at cooling and is a Better power adder at WOT.
I think the real question is- Why don't you get both?
Panther140 is offline   Reply With Quote
Old 09-16-2015, 09:34 AM   #18
^ you never want to tune to where your car relies on the meth, you do it simply for a bandaid. Anyone who tunes the meth into the car is a complete dumbass.
🍼and 🌽 fed coyote.
Old 09-16-2015, 10:01 AM   #19
Panther140's Avatar
and fed coyote.
True.
In fact, one of the best things about water/meth is that you don't have to tune to run it. Cleans the combustion chambers pretty well too
Old 09-16-2015, 12:39 PM   #20
🍼and 🌽 fed coyote.
Lmao, the Steeda car I bought had an empty snow meth tank in it and the guy who had it thought the snow box in the glove compartment was a "SCT chip" and didn't know why the motor blew.
Roofles.
Old 09-16-2015, 12:43 PM   #21
Roofles.
Lol. Did he have the car tuned with it?
🍼and 🌽 fed coyote.
Old 09-16-2015, 01:28 PM   #22
🍼and 🌽 fed coyote.
You don't understand how clueless this guy was. He literally had zero idea about anything on the car. Bought it as it sat and blew it a few hundred miles later. Someone took him for a ride.
Advantages of smaller pulley Rosariors3 New Member Introductions & Greetings 11 09-01-2015 09:52 PM
2002 roush 360r pulley upgrade dgossey82 General Mustang Discussion 0 12-09-2014 07:31 PM
2002 roush 360r pulley upgrade dgossey82 1996-2004 Mustang GT 7 12-05-2014 06:01 PM
Cody, did you change to a smaller pulley? WheelStander 1996-2004 Mustang GT 6 08-18-2012 04:55 PM
Smaller ps pulley? I_luv_HP&trq Pre-2005 V6 Mustang 4 02-28-2006 12:41 PM
10:19 AM
