Gains? - Mustang Evolution
Old 09-08-2015, 01:58 PM   #1
Gains?
I was wondering what kind of power gains I'd see if I did the following mods: cai, professional products typhoon mainfold, plenum and throttle body, steeda underdrive pulley, stage 1 cam, off road x pipe, pypes bomb cat back and e85
Sent from my SM-N910V using Mustang Evolution mobile app
dee_gt is offline   Reply With Quote
Old 09-08-2015, 02:07 PM   #2
Panther140's Avatar
Probably will not gain any power with that setup.
If you skip the E85, you will probably gain (+/-)40 wheel horsepower if you tune the setup.
E85 is for high compression and boosted setups. the fuel is actually 20%weaker than gasoline in terms of energy density, but it has really high stability (octane).
Panther140 is offline   Reply With Quote
Old 09-08-2015, 02:16 PM   #3
Well yea i was gonna get a dyno tune of course
Old 09-08-2015, 02:19 PM   #4
retiredvet's Avatar
Id watch out for that intake. Its in my sig but 2 weeks ago I was sitting in Louisville traffic and heard a high pitched taaaaang shortly after I was smelling sweet antifreeze. It just randomly fractured my ait was 142 my oil temp was 180 and my fluid temp was 190. Lasted all of 9 months. Plastic one is back on
Sent from my LG-D415 using Mustang Evolution mobile app
03 GT 13.4 @ 117MPH best 2v 4.6 w/ auto
Check out my Garage info for what I am installing at this moment~
retiredvet is offline   Reply With Quote
Old 09-08-2015, 02:22 PM   #5
Well damn smh thanks
Old 09-08-2015, 02:58 PM   #6
Panther140's Avatar
What duration, overlap, and lift on the cam are you going for? "stage 1" is not very descriptive other than the fact its probably mild. What are you degreeing your cams at? Does your strategy for degreeing the cam match the strategy that the intake manifold is going for? (Low vs. High rpm power)
Old 09-08-2015, 07:27 PM   #7
Even with E85 he will still get the same gains. Yes it has less energy than gasoline, but the way you said it sounded like he will lose power with E85, which is not the case. You still get the increased cooling and timing. Won't be as beneficial as a FI car. But it will still benefit him.
Old 09-09-2015, 08:49 AM   #8
CAI-Pretty much looks only, the factory intake tubing is already a CAI
PP Intake-Chinese **** intake that will just add weight and heat soak to your motor. Not to mention it does not flow any better than the stock intake. The stock intake is actually a really really really good intake minus the warpage that happens to old plastic after awhile but they are cheap and easy to replace with a new one.
Plenum and TB- Worth doing but gains are minimal. Best combo for the money is the TFS plenum on LRS for $109 and then the Summit 75mm TB for $159.
Pullies-Very minimal gains if any, another looks mod more than anything.
Cams- Expensive as in $1200-$1500 installed or about $1k DIY. Car will need a tune too. This should be the last thing you do if you are staying NA and after all your suspension work is done too.
OR Pipe- Will free up some power but make sure you are in an area where cops will not care as it is a federal offense to remove cats from a vehicle that came with them. Doesn't matter what your state says. The UPR pipe is actually a really good piece OR or catted. They are made in Florida as well so USA made ftw.
Pypes Anything- Sketchy fit and all made in China with really cheap stainless. There are better kits out there.
For initial bolt ons for a 2V it should look like:
-Basic Tune up (COP rebuild, Autolite 104 plugs, fluids etc...)
-Mid Pipe and Catback
-Shifter for manual or J-Mod for auto
-4.10s
-Plenum/TB
-Tuner
-Lower control arms, CC plates, lowering springs/shocks/struts
-Good wheel and tire setup
If you absolutely can't stand the way the stock air inlet tube looks, get the JLT.
Also be very aware that a good 50% (probably more) of things that claim to add X amount of HP to your ride in Mustangland either grossly exaggerate or flat out don't add any. Like when a BBK CAI claims 8whp. No.
Old 09-09-2015, 11:15 AM   #9
Mustang8606's Avatar
Scotty, I noticed you didn't mention anything about long tubes.
Mustang8606 is offline   Reply With Quote
Old 09-09-2015, 02:21 PM   #10
jeno's Avatar
Lol
Sent from my Nexus 6 using Tapatalk
jeno is offline   Reply With Quote
Old 09-09-2015, 02:33 PM   #11
Long.... tubes...?
Old 09-09-2015, 05:52 PM   #12
Hahaha, long tubes. Extremely thick steel. You can't make that s**t up
Old 09-09-2015, 06:39 PM   #13
Gears, gears... Oh, and did I say gears? (:
wawanesa5speed is offline   Reply With Quote
Old 09-10-2015, 06:37 AM   #14
thyreaper's Avatar
Gains?
Long tubes are a real pita and for the money spent on a good set i could put in cams and gain alot more... Cuz most longtubes that are under 600-700 will either rust away or will have problems fitting them and for 700-1000$ for 8-14 rwhp just isnt worth it for me, only how id ever do them is when there is literally nothing else to do to the car.. Which prolly wont happen the life of the car will be so degraded and ill be walking with a cane before that happens lol
thyreaper is offline   Reply With Quote
Old 09-10-2015, 07:23 AM   #15
Stock manifolds are fine unless you are sticking NA and going with ported or aftermarket heads. For a power adder... well the Termi guys usually don't swap out the stock manifolds until they go to a better supercharger if that tells you anything.
Old 09-10-2015, 09:12 AM   #16
Ford did a pretty good job engineering the new edge.
Old 09-10-2015, 09:18 AM   #17
Eh... they did a good job with the supporting cast for the PI motor as far as not needing many "bolt ons". The NPI was a joke performance wise although the 4V was always good.
The SN95/Edge itself is just a refresh of the Fox/Fairmont chassis and there were manual transmission issues pretty much every year except for 99/00 and early 01 with the GT. 05 was when they finally brought the car out of the 70s.
Old 09-10-2015, 08:38 PM   #18
Panther140's Avatar
.. the 4V was always good. //// there were manual transmission issues pretty much every year except for 99/00 and early 01 with the GT. 05 was when they finally brought the car out of the 70s
You literally just listed every major reason I have a 99 cobra instead of an 05 GT haha. Especially the last one. I don't really like the direction they took that car, from an electromechanical standpoint. Plus they upgraded the interior- which is a waste of money they should have spent on reliability and handling.
The newer ones with the yote are cool though. I might own one if it had an eternal warranty on all transducers.
Old 09-10-2015, 09:21 PM   #19
I thought I was making a case FOR the 05+... I dunno.
Eh, the interior is a big deal to the majority of ppl especially the bulk V6 purchasers that keep the V8 afloat. And the 3V is reliable and they DID vastly improve handling in 05.
Only "bad" thing about the 05-10 cars is that the 3V is not exactly a world beater. That got fixed in 11. And, IMO, the 05-09 cars can be some of the, if not THE best looking of all the latemodel Mustangs. For me its a toss up between the 05-09, the 10-12 and the New Edge as far as looks.
Old 09-10-2015, 09:30 PM   #20
natestang07's Avatar
07-09 Gt500 is the best lookingk
Old 09-11-2015, 05:20 AM   #21
That may be my favorite latemodel Mustang. And they are getting very affordable. Like $30k for a completely done verified 700hp one with low miles and garage kept. By the time you get a Coyote and do all the additions and a power adder you are right at the $30k mark or maybe a little more so pick your poison. That is if you get a Coyote with low miles in good shape for the $20-$22k range.
HP gains with Tuning? SaferAngel Pre-2005 V6 Mustang 2 09-10-2006 06:28 PM
cam and sct chip tune gains? tedness Pre-2005 V6 Mustang 10 06-01-2005 10:02 AM
stage 1 v6 = what gains? tedness Pre-2005 V6 Mustang 18 02-03-2005 07:46 PM
gains from porting whipster24 Pre-2005 V6 Mustang 66 02-11-2004 03:01 PM
UPDATE!! BUTT DYNO SHOWS HP GAINS and is accurate Danger Dude Pre-2005 V6 Mustang 46 01-05-2004 09:43 PM
07:35 AM
