Dodged a MAJOR bullet - Mustang Evolution
Old 09-09-2015, 09:20 AM   #1
keeney35's Avatar
So a 2 weeks ago, I heard a rattle from the rear of the car, checked and everything looked good so I assumed it was just a rock in the dust cover or something because it stopped and i didn't hear it again.
Well I was wrong, had the car on the lift today to find rear end oil on the gas tank cover.
Pulled the diff cover and found it to be almost empty of fluid.
After looking harder 3 bolts came out of the carrier Click image for larger version
Name:	ImageUploadedByMustang Evolution1441811784.305901.jpg
And where sitting right hereClick image for larger version
Name:	ImageUploadedByMustang Evolution1441811913.900331.jpg
Name:	ImageUploadedByMustang Evolution1441811966.975784.jpg
Not one tooth was chipped or damaged..
New grade 8 bolts are going in along with a trak lok rebuild kit
keeney35 is offline   Reply With Quote
Old 09-09-2015, 09:36 AM   #2
Strange Mud's Avatar
sweet.
Old 09-09-2015, 05:12 PM   #3
keeney35's Avatar
I re-siliconed the diff cover and lock tighted all the bolts on the carrier and it still is leaking.. I'm having the shop who's installing the cams look at it and see what he thinks because I'm lost
Old 09-09-2015, 09:08 PM   #4
Where was the leak?penion seal\ vent or cover?
ALLYDRIVER1 is offline   Reply With Quote
Old 09-09-2015, 09:11 PM   #5
keeney35's Avatar
Looks like the cover and maybe pinion seal
Old 09-10-2015, 10:57 AM   #6
olerodder's Avatar
Region: Oregon
So..............who was the last person that worked on the rearend and changed gears? Not sure I'd return to the that shop again.
In over 50 years of drag/road racing I have never seen ring gear bolts come loose, especially 3!
Old 09-10-2015, 11:58 AM   #7
Thing is probably going to need a new cover and new seal.
Old 09-10-2015, 12:50 PM   #8
I have swapped many rear gears and never had a leak or a loose bolts. They should have had Loctite applied and torqued. If not then I would talk to the installer.
zipoffs is offline   Reply With Quote
Dodged a Bullet! CrookedHalos 1996-2004 Mustang GT 1 07-30-2012 09:57 AM
Going rate for Bullet take offs? Skip Fix Mustang Parts for Sale and Wanted 2 04-20-2007 05:46 PM
Dodged a bullet Ponycarman The Bar 27 03-22-2005 09:18 PM
help putting together list of bullet proof drivetrain tire Pre-2005 V6 Mustang 6 01-15-2004 11:36 AM
10:52 AM
