Car idle problem - Mustang Evolution
Old 09-11-2015, 02:16 PM   #1
Car idle problem
Hey guys. Have my 02 gt and I've noticed a problem that has just started, never seen it before, wondering if I can get your thoughts. When I'm driving and I put the clutch in and brake to stop at a light, the rpms drop down to an uncomfortably low range, about 4-500 rpm. Almost to the point where I have to tap the gas while I'm slowing down to keep it from stalling. Doesn't happen every time but it's defiantly something I've noticed. Thanks guys!
wawanesa5speed is offline   Reply With Quote
Old 09-11-2015, 05:11 PM   #2
parkerz28's Avatar
I would guess it's the iac bro
Sent from Rapinators trunk
parkerz28 is offline   Reply With Quote
Old 09-11-2015, 05:21 PM   #3
fenixignition's Avatar
02gt here. lemme know when you figure it out lol. i sure havent. and everytime i ask someone they think im paranoid. happens more when i have the a/c running i think. you have any mods? all i have is plenum, 70mm throttle body, ram intake, steeda underdrive, and magnaflow x pipe and borla catback. no tune. changed iac twice. (advance autoparts, not oem part). possible battery issue with an optima yellow top, nothing conclusive. i was thinkin fuel pump was a possibility. injectors looked clean as a whistle.
does yours also seem to lose a bit of oomph when its warmed up?
2002 GT 5sp. 16x,xxx miles
Old 09-12-2015, 08:20 PM   #4
I have basically the same setup minus the Pullies but plus the tune. And YES! When hot I defiantly lose oomph. The car is noticeably peppier when it's cold
Old 09-12-2015, 08:54 PM   #5
I had this problem but it is a V6 and turns out it was the MAF.
Sent from my LG-D851 using Mustang Evolution mobile app
Old 09-13-2015, 04:23 AM   #6
Yea I had an idea it's probably a weak maf. Just so expensive to try and see if that's the issue. But it is definitely related to my intake air temps. When those drop, performance is better.
Sent from my SM-G920V using Mustang Evolution mobile app
Damn idle. IAC/TPS problems? Idle screw? Help! v8pony 1996-2004 Mustang GT 3 05-22-2015 01:39 PM
Set Idle Screw / Idle problem v8pony 1996-2004 Mustang GT 8 05-15-2015 10:07 PM
Idle Problem Help!! W225110 1979-1995 Mustang GT 7 03-30-2010 07:12 PM
Idle problem McGrail482 Pre-2005 V6 Mustang 4 07-13-2009 09:56 AM
94 3.8 off idle hesitation problem crash Pre-2005 V6 Mustang 3 07-14-2008 06:19 PM
» Members Mustangs
none
okfoz
Roanstang
audioAl
Add your Mustang
04:34 AM
