New engine? - Mustang Evolution
Old 09-12-2015, 01:12 PM   #1
LeoGMR4558's Avatar
New engine?
So my cold air sucked up a good amount of water I guess and my car stalled. My insurance might call it a total loss says my mechanic that's looking at a 1,8xxx dollar engine. I do have full coverage. Any suggestions? I really miss my car.
LeoGMR4558 is offline   Reply With Quote
Old 09-12-2015, 02:33 PM   #2
Slater2111's Avatar
New engine?
Take your car back from that mechanic. Go get a low mileage crown Vic motor from 04-05 and swap it out yourself. $700 fix if you can do it all yourself.
What CAI do you have and how did you manage to suck up enough water to do that? Seems like you'd either have to be in a giant puddle or full throttle though one.
Slater2111 is offline   Reply With Quote
Old 09-12-2015, 03:37 PM   #3
torchdNblazen03's Avatar
My car has done this before, not a total loss but the car did stale out after hesitating and sputtering for a quartermile.. I hit two huge water spots in the road(would have avoided them but another car was coming and I was on a back road) anyways my CAI is fender mounted as I'm sure yours is too.. and that's easy access for puddles of water to get up in there, especially if your going at a good rate of speed.. I was already pulling into work when it died, I tried starting it back but it wouldn't turn over, next break I had it fired right up. Next day I went and replaced the filter and it was as good as new.. You must have got a TON of water in there for it to be a total loss that sucks man.. Even with full coverage they aren't writing you a check for your loss??
torchdNblazen03 is offline   Reply With Quote
Old 09-12-2015, 04:06 PM   #4
LeoGMR4558's Avatar
No check so far, yeah I was WOT going the the puddle. It sucks bro
Old 09-12-2015, 04:38 PM   #5
LeoGMR4558's Avatar
Old 09-12-2015, 09:16 PM   #6
I kno it has to suck I'm sorry man... so did your car die immediately after hitting it or did it act up first, just curious??
Old 09-13-2015, 12:52 AM   #7
LeoGMR4558's Avatar
Well I cleared the huge puddle but as soon as I got out it just died, I'll turn the key and I'll just hear the starter. What if I just drain the engine?
Old 09-13-2015, 08:08 AM   #8
Slater2111's Avatar
You can try that. But if water made its way to the cylinders you could have bent valves and other things. Never hurts to try. Take out all the spark plugs and pull the reset fuse for the fuel pump by the tail light and turn it over and see if anything comes out. Obviously don't do it without oil.
engine making belt noise engine ticking sounds like a diesel 3k miles on car Yellow50 2011-2014 Mustang GT 34 05-04-2012 09:56 AM
Engine died at low speed. Could not start engine in hot weather Ucla1998 Pre-2005 V6 Mustang 5 08-09-2011 02:15 AM
Engine noise from COLD engine 03GreyMach1 1996-2004 Mustang GT 10 03-14-2008 07:40 PM
engine swap 1989 to 1992 4 cyl engine dannyc1992 General Mustang Discussion 0 02-08-2008 01:59 PM
Engine Swap/ Engine Shakes too_cool_mitch Pre-2005 V6 Mustang 2 02-28-2006 02:01 PM
04:35 PM
